I took advantage of some holiday specials and am building a new computer for myself. Currently I have:
ASUS A8N-SLI Deluxe
Athlon64x2 4400+
BFG 8800GTS 640MB OC
4GB Patriot Performance DDR PC3200
Antec SmartPower 450W
3 SATA 7200rpm HDD
22" LCD @ 1680x1050
It's been a good system and lasted me over 4 years. I have been wanting to build a new computer for quite some time but 2009 was a rough financial year for me so I had to keep pushing back my build. I really wanted to build a machine around an i7 920 but I just couldn't afford it. I came across a great combo deal on newegg for the following parts and decided it was a great upgrade for me at a very nice price:
AMD Phenom IIx4 955 BE
ASUS M4A79XTD EVO
GSkill DDR3 1600 4GB (2x2GB)
I am only buying what I need right now, and will upgrade as I am able. I will be using my 8800GTS in the new build because a new GFX card doesn't fall into the 'need' category. Same goes for the HDDs. However, I am in need of a new PSU. Mainly because my current one is low on wattage and it likes to 'chirp' from time-to-time, which means it could go any day. I plan to OC my processor and when I add a new video card, I plan to use my 8800 as a PhysX card.
My Questions:
1. Based on the parts selected and the fact that I want to OC and eventually add a new GFX card using my old one as a PhysX card, what is the minimum wattage I should be looking for in a PSU?
2. Do you have any recommendations for a budget PSU and/or a PSU&tower combo? I have been looking at this one. I could use my old case, but it has very poor airflow. I would say that the most I am willing to spend on a PSU and case combined in $150-$175. Obviously, the less expensive the better.
3.Can I expect a noticeable performance increase with these new parts even though I am using the same GFX card?
ASUS A8N-SLI Deluxe
Athlon64x2 4400+
3 SATA 7200rpm HDD
22" LCD @ 1680x1050
ASUS M4A79XTD EVO
My Questions:
