Like i said in my other post, parts made for the BTX wont need all that much cooling because they are made to produce much less heat than there ATX counter parts.
Suppose that the air increases in temperature by 3 degrees before it reaches the HSF where it increases by another 9 degrees. Leading the cold air directly over the HSF would increase the temperature of this air by 10-11 degrees, after which it increases by another 1-2 degrees. This is because the ability of air (and water) to absorb energy ('heat') decreases as it absorbs energy.Originally posted by Black Morty Rackham
Hmm, I don't really know. I guess it depends on how much the CPU temp is effected by the temperature of the air used to cool it. If it's not such a big deal, then the "furnace approach" is better.
while if this situation were reversed, the CPU would be cooled even more, but at the cost of the ability to cool the other components with the efficiency displayed in the former case.
Ever notice how children sometimes come up with ingenious solutions that you would never, EVER, have thought of?
Less obvious may be the fact that the efficiency at which air absorbs heat decreases in a non-linear way.Originally posted by Black Morty Rackham
Duh.
It's hard to say without having a way to simulate it, like using a BTX-like setup to take measurements with temperature sensors.Anyway....
Yes, that's what I've been saying for a while now.![]()
What I want to know is how big a deal it is.
Originally posted by Elledan
In all rackmounted cases I've seen, the air entering the case first flows over the HDDs, then it moves to the back where it cools the CPU and other components on the mainboard. The mere suggestion of redesigning rackmounted cases to squeeze a BTX system in them seems utterly ludicrous to me.
...hey, I resemble that remark....Originally posted by Black Morty Rackham
Engineers often drown in their own knowledge, so they won't see the optimal solotion.
Originally posted by LeftSide
Yes, but with a rackmount you dont care about noise. You can have as many fans as you want. With btx they are talking about 1 fan in the front over the cpu, and 1 fan exaust out of the psu. Im sorry but unless your fans are spinning realy fast like, the hd and vid card will get just to hot. Specialy with oems.
Very good points.Originally posted by Party2go9820
Don't forget that lots of OEM's now only use 1 fan - the one in the power supply. (I'm not counting the the cooling fan directly on the HS because you need that no matter what). Some have an additional exhaust fan right behind the CPU with some ducting, but those are far and few between. OEM's will figure out the best and cheapest way to cool things with least heat buildup.
With rackmounted cases I think that the way they're designed has much more to do with the way they're use rather than because of attempts to optimize the cooling of the components.Originally posted by _wiggin_
I have spent a lot of time in datacenters, and can attest to the fact that this design follows some of the ideas BTX is designing around. In a typical desktop machine, the CPU will be the component producing the most heat. In a typical rackmount file serve, the array of fast-spinning HDs will generate much more heat than the CPU(s). In the rackmount, as in (as I understand it) BTX, you are putting the cool air over the hottest components first.
then again, they don't run very cool...Originally posted by qdemn7
Very good points.
Dell has fabulous thermal engineering. I have a 2 year old Dimension 4400 P4/2.6ghz, and the thing runs so quiet, I can barely hear it running.
Originally posted by Wixard
So whats amd going to do about this? They dont seem to thrilled with going btx. From what ive read they dont plan to, maybe another rambus vs ddr type war.
Yes, it would. Just like the RAM, northbridge and all other components inside the case. Except for the CPU, which would be nice and cool.Originally posted by Atragon
Another thing is with the way they're redesigning add-in cards to have the componants fliped around, wouldn't this stick the GPU HSF right into the hot air comming off the CPU?
A friend of mine has a Dell (Dimension, I think)... one fan at the CPU (well, in a duct behind it, really) and one at the CPU. It makes an incredible ruckus. The processor fan has to run at insane speeds to cool it enough, I suppose. Not a good design. Plus how much of a hazzle changing anything inside it is... I wouldn't call it a good case design.![]()
Yes, a Dell should be very quiet. A noisy fan should be replaced if still under warranty.Originally posted by Party2go9820
If its really that loud, it sounds like a hardware problem - maybe the fan is failing. Most OEM's - Dell's espicially - are extremly quiet.
Originally posted by kronchev
its not a furnace, youre trying to get heat AWAY from something, not heat up air
Originally posted by emorphien
I don't know, it kinda makes sense to me. You're trying to get heat away from a furnace too. Otherwise it won't heat the house (assuming air heat).
but the elements of a furnace can stay hot and thats OK, in fact thats probabily most desirable. there is only one really, really hot part of a computer, the CPU, and you want the CPU to have the best chance of dissapating heat
I'm having an internal debate about which I think would be better. How big of a cooling boost would the CPU get with BTX over having some of the cold air coming in over other components that need cooling too
Having it come over them and hitting the CPU last pulls more hot air from the case, which in turn makes for a cooler case, which might have a bigger effect on dropping the CPU temp that we're thinking.
Personally I think they should have two ducting systems, one for the CPU and one for the other goodies to cool all of it in a very effective manner. Just use one 92mm fan for each and a duct and it would work quite well.
eh, I'm not prepared to cool the CPU at the expense of the other components.
And a cooler case means a happier case, this isn't making cases cooler.
Hence I'd prefer two ducts, one for the CPU, one for everything else.
well, us modders will have our way with these and make them actually efficient for OCing i'm sure![]()
BTX will keep the case nice and warm, while ATX will only have higher CPU temperatures with a poorly implemented cooling solution (re: ducts).Originally posted by Spearboy
would this be right to say. btx keeps the case at a more even temp, while atx keeps the case cooler but the cpu hotter?
Originally posted by m³ñ
I have a Dimension 4100. It has no fan on the HS. It has a duct with a fan on it.
