Source: The InquirerA FIRM which makes a disc that can hold 60 times more data than a DVD said it is ready to release the product next year.
InPhase Technologies, based in Colorado, has developed a commercially viable version of a holographic disc which can hold 300 gigabytes of data and can be used to read and write data 10 times faster than a normal DVD.
InPhase Technologies spokesperson Liz Murphy said that unlike other technologies that record one data bit at a time, holography allows a million bits of data to be written and read in parallel with a single flash of light. This enables transfer rates significantly higher than current optical storage device.
The discs, are 13 centimetres across and a little wider than normal DVDs. They store data in a light-sensitive crystal material using the interference of laser light. A single light beam is split and passed through a semi-transparent material. This acts like a filter, changing different parts of the beam to encode bits of information.
The altered beam and the reference beam are then recombined in the light-sensitive material and their pattern of interference provides a record of the encoded information.
Technology Tour
VIDEOS:
1. Inside The Box
2. Data at the Speed of Light
Source: InPahse Technologies
