I'm still getting random SLI usage of 60% on BF3.. is anyone else having this problem? The game runs like crap at 60% usage!
Anyone get this or is it just me???
I've run these drivers in Skyrim on Ultra 1920x1080 for 8.5 hours based on gameplay stats and zero problems - Skyrim looks awesome.
I've also run these on BF3 and I had a few of the typical problems with the whqls that are currently out but definitely not to the same extent and it appears to have minimized the not responding problems that have popped up so I believe they're working on the problems there.
Overall great drivers for me, I'll be keeping them.
2600k @ 4.4 here, 580 SLI. i'm getting slowdowns in skyrim @ 1080P (ultra) in towns, (30-50 fps). anyone?![]()
I got my first blue screen in years playing Skyrim with this driver. Not sure if it's the game or this specific driver, but it certainly wasn't a good thing.
Yeah, been happening to a lot of people it seems. Check your GPU usage, I bet its down near 30%. With Sandy Bridge CPU at 4.4 GHz it's pretty obvious it's not a result of CPU limitation either.
There's a couple posts about it over on the Nvidia forums, but who knows what's going on at this point. Pretty frustrating...
Have you ever played Fallout 3, New Vegas, or Oblivion with mods? Yeah, it is the cpu. This game loves a fast cpu just like all open world games do.
So, to max out the game, without mods, with the highest in game settings you need a SB CPU clocked higher than 4.4 GHz like the guy I replied to? I understand open worlds are demanding on a cpu, but that seems pretty out of control.
For the record, I played FO3 and FONV with mods on the same rig I'm using now with much better performance and higher GPU usage.
With what mods? I see some nice dips in FO3 with the mods that I use and I don't go crazy with the mods either. I saw some nice dips in vanilla New Vegas with an i5 760. I don't know about you but I can max out Skyrim game fine with my i5 2500k and GTX570. Yeah, I see some dips but for the most part its smooth. If need be turn down the shadow quality a notch, it will free up a ton of performance. The graphics options are there for a reason. I don't understand why people bitch so much when they can't max out every option.
Hell, I'm playing the game in 3d vision right now and only turned down a couple of settings.
Sure I can max it but it's just kind of odd that it can drop to a stuttering 25 fps in some cities with 20% usage on each GPU. I've tried turning down various settings and it has practically no effect. Other than playing the game on all medium, I can't get above 35 fps in cities.
So, what? Drop the shadow quality one notch. Its hardly noticeable. None of these types of games are very demanding on the video card.
I already have shadows in High instead of ultra and it isn't changing anything for me. I tried turning them down to medium and still no change.
Yeah, I just saw your edit. That isn't right. Have you tried a different driver? Does disabling sli help? 280.26 is working really well for me.
I might try rolling back to something tonight. I was under the impression that only the 285.79 drivers have the SLI profile for Skyrim though.
I think you'll find the slow down in towns is due to a large amount of over draw when looking in certain direction. In if you walk near to the edge of a city and look out towards the outside world the frame rate will be fine, however if you do a 180 and look at the town the frame rate will take a nose dive. The engine seems to draw everything within the view distance regardless as to if it's visible or not, you could be staring at a flat wall in front of you and the frame rate will take a huge hit provided there is a bunch of stuff behind it.
Certainly seems plausible, bu I've tried various levels of draw distance reduction for objects, terrain, etc. and nothing seems to make much of a difference really. Maybe somethings just borked for me personally.
Just install 285.79 on top of the existing drivers. You will be fine.Sorry guys im new to nvidia drivers. I want to try these beta driver for my gtx570. How do you guys uninstall old drivers. Thanks
