NEW (and OLD) computer wont show display!
Hello i recently built a new set up:
Core 920
Gigabyte ud5
3x2gb Corsair Ram
Pc power 750 watt psu
2x150 vraptor/1x320 seagate
evga 8800gtx
benq 24inch mon
my old setup was:
q6600
dfi bloodiron
2x1gb corsair
same power supply Pc power 750 watt psu
same vga 8800gtx
im going to be as specific as possible with the story of how my computer wont show bios or no display... i recently upgraded the driver on the 8800gtx as it was continually crashing on w0w (i forgot to uninstall the old driver) after installing the new driver i turned the computer off. Later the next evening the computer wont boot into bios or show any display so i thought it was the mobo so i then bought my new setup. After building my new setup there is still no display and it wont even boot to bios. It seems that all the components are workin as all the fans are spinning and i tested out the vga on another computer and it worked. Can someone help me please.
Read the basic troubleshooting guide stickied here in General Hardware. There's a portion there on what to do when no video shows up.
hmmm well i tried everything that the troubleshooting guide and yet no video shows up. it seems to power up fine but i still get no video or a POST
- Did you reassemble it outside of the case?
- Did you plug in the power cables for the video card?
- Did you plug in the 4 or 8Pin CPU connector?
- Did you plug in the 24Pin connector correctly?
- Did you plug in the video card correctly?
- Did you plug in the RAM correctly?
Did you try another video card? Maybe that Geforce 8800GTX crapped out or is acting flakey. Try another video card instead.
