DWolvin
- Nov 13, 2002
Are you using iced tea?
Current state of my basic custom loop. Going to vertically mount the GPU with a Heatkiller V block soon.
Not sure what you mean by iced tea, but if you're asking about the coolant, it's 70/30 distilled to Toyota coolant.
Got my Heatkiller V FTW3 block installed on my 3080Ti. No more ice t ea coolant.
IT'S GOT WHAT PLANTS CRAVE!Mountain Dew?
Thanks!Love the staircase!
Hmmm...Didn't think of it that way.Sir Beregond build looks like a pc you would expect to see in some middle eastern dictator's palace; With it's gold and white theme. All that is missing is the hunting falcon and an exotic car at the front entrance.
Well it can easily pull 1000w from the wall even with the Radeon's undervolted. the 2x 360 60mm was fine for just the GPU's before but I figured I better add a third rad due to the CPU pulling a good bit of power as well now.Thicc
This is not done as in not cable managed (yet) but finally got my 1950x setup with my 3x Radeon VII.
Nice to put the Heatkiller block i got from ~ever~ to good use.
View attachment 490645View attachment 490646
Edit. Also added a second pump which I can tell makes a difference. I could visibly see the water in the resevoir was moving much faster when i turned the second pump on
Regarding the cpu lines, my motto is, maybe next time hahaha. That distro isn't doing you any favors either. Its offset just enough to jank up your bends.My CPU runs leave something to be desired.... trying to figure out if I can run a third radiator on the bottom while still having a mini itx system there.
Hey I know this rig! I always call it the octopus rig.
Really nice! What size are the other two rads?
First time is always rough, I made my first hard tube loop last year. When you get more than one bend per segment the complexity skyrockets. What I found extremely helpful was to make some jigs using bricks, so I always had a 90 or two to bend against. I also had drawn out the distances I needed for each turn, which got me really close and then test fits allowed me to make minor adjustments. Take your time, my segments with three bends took me on average five hours a piece!I have always heard that custom loops aren’t worth it other than for looks and sound levels. Decided to go for my first build due to how hot my 7950x is
Seems to be worth it for my 7950x.
$350 not counting the heat gun.
Heat killer IV pro
Alphacool Nexxos 45mm rad
Alphacool VP655 pump with their body.
Cheap Alphacool 150mm reservoir
Barrow fittings.
So for $150 more than my aio. I get core parts that will last ages.
With my ek 360 aio it would run 95c and drop to 5080mhz. With the custom loop it’s right under 5.4 at 86c. From what I can tell it maxes out pbo in all circumstances.
I can do an all core overclock and have it swap from pbo after a certain current draw.
I was able to get 5.5ghz all core at 1.28 volts with the same 86c. Could probably push further, but it looks like 5.6 needs more than 1.32 volt and don’t wanna kill the chip.
Not happy with my bends. Guess they are fine for a first attempt. One tube is tilting the reservoir a few degrees. Plan on getting a block and extra rad for my 4090 when they are available. I’ll redo it then.
View attachment 522832View attachment 522831
Thanks for the info.First time is always rough, I made my first hard tube loop last year. When you get more than one bend per segment the complexity skyrockets. What I found extremely helpful was to make some jigs using bricks, so I always had a 90 or two to bend against. I also had drawn out the distances I needed for each turn, which got me really close and then test fits allowed me to make minor adjustments. Take your time, my segments with three bends took me on average five hours a piece!
