BeerEngineer
- Feb 22, 2017
AMD
1700x Asus CrossHair IV Hero
Corsair Dominator 16gb 3200mhz (on QVL)
Corsair hx850
Ekwb p280
Gigabyte gtx 1080
My digital sad 480gb
When psu is turned on, the lights on the motherboard illuminate.
The CPU ready light is green.
No q or error codes displayed.
Trying to power on the system by case, start button directly in mobo, and by shorting the power btn header fails to spin up fans or turn on the water pump.
Power supply is from a known good system.
Removing the atx cable and using a psu bypass atx connection turns on the power supply.
I tried replacing my gtx1080 with a known good gtx970.
I've disconnect all of the peripherals.
Verified a pwm connection is plugged into the CPU fan header.
Verified the 8 pin atx CPU fan is plugged in.
Any quick hit items that you all can share with me?
Otherwise I think I have to go though the pain in the butt of setting up the motherboard outside of the case to rule out shorts and then RMA.
That's a huge pain. Hopefully it doesn't come to that.
Thanks in advance for any thoughts you can share.
Corsair hx850
Ekwb p280
Gigabyte gtx 1080
