You can repay us by making it look like your loop is running a nice frosty ale through its lines, carbonation effect would be a bonus (of course, only in effect, as I know air in the lines is vvvvvvery bad lol).I love you guys.
Me either, I just remembered reading about it and it also struck me as Wow! What! But one after another had this problem as time went on. Now I am thinking of setting up a custom loop with an EK kit so seeing how this turns out will be good.In-freaking-credible! I would have never guessed that a rubber gasket would cause such problems. Color me amazed! Kudos to noko for finding that information.
Definitely something to file in the "weird stuff" folder!
Yes a rubber can stop babies too. LOLThis looks like one of them where a piece of rubber stops booting
It's happening even after a cleared CMOS (see: system at 100% defaults)? Or is it only happening when you clear it and re-apply your overclock settings?Ugh. The first day I played around with overclocking I'm getting a Q code of 8.
Tried clearing cmos, tried reflashing. Neither appear to be breaking it free of the code 8 system initializatiom agent issue.
Pulled CPU block, CPU, reinstalled CPU, installed CPU block after trimming intel flaps from backplate, installed block gently.
Bios flash from USB.
Booted.
Worked.
This board and install retention are so finicky...
Well that is solid advice for someone troubleshooting.I like to wing it, I always do the complete build and then cross my fingers , although I will make sure it posts *before* I spend an hours doing cable management.
Which is why I suggest building outside of the case to make sure all parts are in working order.kind of the opposite but in a case like this, I'd just narrow it down to the board and psu, then start adding stuff one at a time as he has. Shorts are a pia to nail down.
A replacement gasket arrived from ekwb in a little less than a week. I haven't installed it yet, but I will soon. I'm thinking about doing a quick test with the multimeter with the probes at a set distance apart to see if I can see a difference in conductivity between the old and new gasket.
