Mainly gaming and webbrowsing
Trying to keep this upgrade under $500, but realistically, as little as possible for good performance. Yes.
3) Where do you live?
Washington state
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, MoBo, RAM
6) Will you be overclocking?
Quite possibly
24" (1920x1200)
Within the next month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Currently using a RAID0 setup on an nForce motherboard. Ideally I wouldn't need to reconfigure raid and could just use this setup... not sure if this is possible with an entirely different raid controller.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Win7 x64
I have some components in mind:
Processor: Phenom II X4 965 - THis seems like really good bang for the buck. There's an Intel i5 that has similar benchmark performance, but the price is slightly higher. A new processor is my primary reason for upgrading - I've got a Core 2 Duo E6750 right now, and it's starting to lag behind in games
Either of these motherboards (leaning towards the ASUS since it's cheaper and the only real difference is the listed memory speed, SLI support, and # of SATA channels. Asus also has a 3 yr warranty)
Buying memory is a little more difficult, and the main reason I'm posting here. I've never bought DDR3 before due to the higher timings. I'm kind of confused by the way the motherboards list their maximum supported speed - it looks like the ASUS board will support DDR3-1600 if and only if you've overclocked it. Likewise, the MSI supports "DDR3 2133 OC." Am I understanding right that you'd have to OC the processor to use these types of RAM?
From browsing around the forums, it seems like most people believe that there's not much advantage in DDR3-2000 over DDR3-1600, and since prices are cheaper on the latter, I was thinking about getting 4 or 8GB of this ram:
Finally, do you think I'll have to reformat the drives that are in RAID0?
What are your guys thoughts on this build? The RAM in particular is kind of up in the air.
Thanks guys!
Washington state
CPU, MoBo, RAM
- Antec Nine Hundred Computer Case
- OCZ GameXStream OCZ700GXSSLI 700W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
- Creative Sound Blaster X-Fi (PCI)
- Radeon HD 5850
Quite possibly
24" (1920x1200)
Win7 x64
Thanks guys!
