Hi all, here is my shopping list for a new machine Im building, any help / comments / advice is welcome and appreciated.
THE PARTS
CPU: Intel Core i7 3820 3.6GHz 10MB LGA2011 (Main reason to go with this is the quad-channel memory lines and the 64GB as the max memory supported. Worst thing about it is the TDP130W and the heat it may generate. Power consumption is no issue. Also this will replace a 2600 that never-never works over 50% under actual working conditions so processing power here is plenty. ) http://ark.intel.com/products/63698 )
MOBO: Asus Sabertooth X79 Intel LGA2011 ( http://www.asus.com/Motherboards/Intel_Socket_2011/SABERTOOTH_X79/#specifications )
RAM: 2x Corsair Vengeance - 32GB 1600MHz PC3-12800 (4x8GB) ( http://www.corsair.com/en/memory-by-product-family/vengeance/vengeance-32gb-quad-channel-ddr3-memory-kit-cmz32gx3m4x1600c10.html )
(for a total of 64GB of ram at 1600 which is the fastest and the max amount the mobo and the cpu will support)
SSD: Corsair Force GT 240GB 2.5" SATA-600 ( http://www.corsair.com/en/ssd/force-series-gt-ssd/force-series-gt-240gb-sata-3-6gbps-solid-state-hard-drive.html )
GRAPHICS: 2x MSI GeForce GTX 560 - 1 GB GDDR5 (I already have 1 of those, the 2 fans version, I want to get a second one and run both of them on the same machine) ( http://www.msi.com/product/vga/N560GTX-M2D1GD5.html )
SCREENS: As for screens, the 2 GTX560 have to drive 4 identical x Samsung Syncmaster2443 24" 1920x1200 screens which I already have.
PSU: Corsair - Enthusiast Modular TX850M - 850 Watt (The system has no blueray/dvd/cd unit and no other hard drive. The PSU only has to power the 3820 (TDP130W, the 2 GTX560 and the SSD.)) ( http://www.corsair.com/enthusiast-series-modular-tx850m-80-plus-bronze-certified-850-watt-high-performance-modular-power-supply.html )
CASE: Im unsure about the case, any suggestions? Something that can hold the 2.5" ssd in place, with good cable management and plenty of fans / ventilation. Design is not important as it will be hidden behind the table out of sight.
MAIN CONCERN
COOLING: My main concern is the heat from the 3820 as it has a TDP of 130W. I think this is asking for some liquid cooling system, but I have never installed one before Im afraid I may get something wrong and destroy the system. Are they difficult to install ? Any model suggestions? Does water cooling needs a special case? Will a normal air cooling be enough to cool 130w of tdp? Thank you.
WHAT IT WILL DO
Finally, this would be my main desktop, replacing a SB2600/16GBram/60GBssd.
I use it mainly for software/database development, and I virtualize a lot. My main bottlenecks with my current system are the SSD (60gb) and the ram (16gb) (both always running at 9x%) as each virtualized system may take anywhere from 1 to 4 GB of ram. Also since I go full screen with the systems, jumping from 2 to 4 screen is going to make a huge difference. Right now I can see the host on 1 screen + 1 virtualized on the other.
I clone/spawn different vm for new projects or to handle some files / sites when I dont want to leave traces of them on the other systems. It helps a lot from a security point of view. Also for performance tuning you can clone an entire system, change 1 variable and watch the results and get very valuable data.
This is not a gaming computer. I may occasionally play ancient games, counter stike 1.6, age of empires 2 with a hack to go full screen on 2 screens, perhaps some minecraft and other really ancient stuff from time to time, Im not into the latest games.
I do no overclocking, my 2600 doesnt have a K on it.
It will run 24/7/365, if go on holidays it stays running as I will remote into it or other people regularly connect to some of the virtualized machines which act as svn development / testing servers for different projects.
My host of is a flavor of Linux
The whole setup is behind a surge spike filter and a ups battery with more surge protection to further shield it.
Any suggestions, comments or help is very much appreciated, thank you all for reading so far and for any comments.
THE PARTS
MAIN CONCERN
WHAT IT WILL DO
