Neutronium (Alpha) v3 Build Log
Yeah, the PCIe 16x ribbon was a flop for what I wanted to do, not quite flexible enough to give me 3x 90 degree turns. So, this setup gives you the best opportunity for large air cooling; dual AIO water can really go either way, chimney over the motherboard or out the front.
Personally, I identify more with the design style of Fractal Designs than any other case out there, so trying to keep the front/top as blank as possible. (newest idea is a plexi formed tube to direct air out the back).
I'm exploring other build ideas as well (clamshell design, tray & lid design, individual panels)... trying to find what would be the easiest / cheapest to produce with this range of volume (sub 7L w/o leg, sub 8L w/ legs).
sorry for the slow going, it's about $70-$80 (materials only, not including time/rockstar) each proto iteration; yet another reason I'm kicking around the idea of getting a stereolithography printer :D I didn't help matters by picking up a pair of 4TB hdd's today b/c my array ran out of space :eek:
I'm not sure if the 3D printer would cut prototyping costs or not, but it would be a new toy at the very least... You could compare the iteration cost for stereolithography and cnc, see if the difference is equal to or close enough to the cost of a 3D printer.
In terms of manufacturing... Having 2 interlocking U-shapes to form the case seems to make the most sense to me. Seems like it would require the least amount of cutting and would result in less wasted material each run by only having 2 distinct parts. I'm not an expert though, it just seems like it makes the most sense for efficiency.
I think the Node 304 is probably the nicest ITX case around right now, seriously dig the styling and minimalism to it.
I hope to design a case at some point down the road because I'm super-specific about what my ideal case would be.
Wish you mad luck with your current project!
Yeah, no way the SL printer is worth it for this project alone, but it would be an awesome geek toy (and may be a net saving over the long term depending on maintenance/supplies) :D
I agree on the dual U's (the way the langear infinity was made), just getting it to all go together without screws exposed will be interesting, probably have to use beveled edges on the U's so they interlock with a couple shell mounted (so screw through the bottom of the sled) screw points for the top shell sides and screw through points on the rear.
Slight update:
I'm at a decision point.
I can build an SG05 mod, which will accept full-length (up to gtx 680's), full-height, double-slot graphics cards, for a modest investment (a couple hundo once all supplies/bits are added in). This will get me under the 9L limit for µSFF designation (sketchup swag at 8.5L).
Alternately, I can build a scratch case ($200-$300), import a Zotac Twincooler ($425), mod the gpu with straight (instead of 90 degree up) pcie power plugs, toss good airflow (and all my warranties), and go for the smallest build possible (current sketchup swag is at 4.9L).
I don't know that the smaller build is worth it, especially at the significantly increased cost and the fact that it, in all likelihood, will not be gpu-upgradeable. What do you all think?
Slight update:
IMHO, the second option will be more [H]. The 1st option just less challenging :p
Gonna step in and concur here...
If you want an easy out, go with option A.
The second option sounds totally badass (and expensive) though.
This is a question you should ask of your pocketbook and yourself ultimately. How much is -3.5L worth to you?
The additional work, additional cost, lost value of warranties (something could fail, it happens), decreased airflow, and the inability to upgrade the GPU seems prohibitive to me.
Not trying to scare you off the idea either, just putting it back on the table for you.
8.5L is a tiny little beast if it'll fit a GTX 680 with decent thermals...
Yeah, I'm kind of shying away from option 2 mainly because of $$$ -- just dropped $2k on our two cars and would like to get my wife's student loans (and our condo) paid off on the next couple years (it's sad when [H]ers get old, right? :p) Dunno if I can expend the level of effort that would be required to do that job justice.
As to option #1 -- yep, it will fit a gtx680 no worries. It is basically what I think an SG05 should look like, without a spinner and shortened a good bit.
well if you go with number 1 then you forfeit the smallest gaming rig title to me. so theres that to consider. :) modding is fun, and its a good hobby to spend your time on. if you have real life stuff thats getting in the way though, then obviously that's more important than a hobby. too bad, i want to see this build!
lol -- there is that... (though to nitpick, 8.5L < 8.62L :p :D)
It's not like $ are getting me down, it's just the magnitude of the $ that I wasn't expecting. If I can find just a twincooler hsf/mounting on a mod site from someone who went AIO water I'd gladly pay the $300 for the custom case.
Sketchup Swag of Option 1:
Front:
Back:
I used a H67N-USB3 because I don't have a model of a z77e-itx. I will also probably be using an AXP-100 instead of the samuel17, so the fan will move a bit (this will allow power plugs/cables to work just fine). Obviously the Twincooler model is complete swag (I suck at sketchup).
Front face is blank brushed aluminum (anodized black), GPU side will have a black mesh/filter opening for most of the side, hdd side will have a small mesh/filter opening from the bottom of the hdd's down to the top of the mobo, and there will be black mesh/filter opening between the I/O and the psu. The only thing on the top will be an opening in front of the psu to allow hot air to escape (same black mesh as other openings).
Other assumptions I made:
- I expanded the 2.5" hdd height to 15mm to simulate the wd 2TB green drive. The 2x 2.5" ssd's are 7mm to replicate samsung 840 pro's
- LEDs for various activities (hdd / power) can line up rear-ward of the two USB ports on the side (also the headphones / mic plugs)
- Case height may go up a bit to accomodate the pcie power plugs (so I don't have to mod the on-card female plugs).
i love it. totally love it. finding a heatsink like that is going to be hard though. the only thing i can think of that will fit and might also have adequate cooling capacity is this. how tall is your case now? i think for mine i decided that with normal (3/8"?) standoff and a full-height gpu, 5.5" is just about the shortest it can be with power plugs on top. i would definitely make it .25" taller over resoldering the power plugs. do you really need two SSDs? it would be nice if you could just use a single 512GB SSD and a 2TB HDD to give them some more breathing room. packed that close and with literally zero airflow im worried about the 2TB drive's longevity.
It would be a space to mount up to four 7mm laptop drives (the holes would be there). In order to channel airflow, there will actually be a flat piece of 1mm aluminum which is attached to the four points between the heatsink and fan, as well as to two 50mm standoffs above the motherboard mounting points on the hdd side of the case. The hard drives/ssds will bolt into that on the bottom and a mesh piece from the back and side rails on top.
The airflow design behind this case is broken into three zones:
- Zone 1 (GPU) is self contained. In through the side and out through the back / top.
- Zone 2 (lower half of main chassis area). In through the mesh filters in the back and side and up through the main heatsink & fan.
- Zone 3 (upper half of main chassis area). Primarily exhausting the air coming out of the main hsf / fan through the roof as well as convection for the ssd/hdd's.
Thank you for your comments; what do you think about making the entire roof of the case mesh so that the hard drives could cool via convection? Flip the PSU over at the same time to make a fourth zone of compartmentalized air?
I wanted the dual SSD's mainly for Raid 0; I recently built a dual samsung 830 computer for a buddy and it obliterated my current computer, so i've drunk the koolaid :p :D
The case in it's current iteration is 130mm tall. I will definitely need to increase that a bit. I can fit the full size pcie power plugs with a 135mm height, but I may just go to 140mm height for GP.
The two CPU heatsinks that could make this work (as I see it) are the AXP-100 and the Samuel 17, there might be others out there, but I don't know of them off the top of my head.
That video card heatsink is the approximation of the Zotac Twincooler; I'm still trying to track one down. I really don't want to take the penalty of going from a 4GB 670 to a 2GB 670 (I game at 2560x1600), or I'd just buy one and sell off my old GTX 670 4GB.... wonder if I should just do this anyway :p
well a 512GB SSD is basically 2x256GB SSDs raided together from what i understand. meaning that your friend probably would have gotten about the same speeds with a single drive of twice the capacity. i cant find any studies about this after a quick google, but i thought ive read it multiple times. hopefully someone can verify/debunk this.
do you have any case fans? im very worried about the cpu and mobo cooling currently. you have the fan pulling air up, but the air is basically blocked on all sides by the i/o plate/gpu/ram/24-pin and sata cables. i think that flipping the psu and the cpu fan would be a lot better if you have mesh or some small fans at the top in front of the psu in order to let plenty of air through to the cpu fan. you would also get better cooling to the psu with fresh outside air instead of hot air right off the cpu. i defiitely like the top panel being mesh. :)
for cpu cooler, i dont think the axp-140 will work. it is 70mm tall without a fan, and the psu is ~65mm, which is already 135mm total not accounting for the mobo/standoffs height or a fan on the axp. the samuel 17 is 45mm tall so 110 with the psu and 135 with the psu and a normal-thickness fan. the axp-140 is an awesome heat sink, but it has so much wasted space between the base and the fins. and it has heatpipes coming up in the center which keep you from putting a fan under the fins instead of on top. the other options are shuriken or kozuti i think, so samuel 17 is best.
for gpu cooler, did you look at the accelero i linked? if you cant find the twincooler then that would be the best (maybe only) other option. they are really good quality and performing coolers and since the ram chips are right next to the gpu socket on that 670 it should help cool them too. add some copper or aluminum sinks to the vrms or whatever in back too. this would exhaust into the case, but i think that would be fine if you have a mesh top and not a lot of ways for the hot air to get to the other side of the pcb.
Raid0 on the SSD's produces some ridiculous #'s at least for sequentials, still looking for some #'s on IOPS, but his system felt significantly snappier than mine (I mean as in it took 4 reboots until I could time the "beat the crap out of the delete key to get into BIOS" properly, lol! [edit] though this doesn't make sense since POST comes from onboard chips... hrmmm....[/edit]). Either way, that mounting area will have the capability / mounting holes for four drives, don't have to use them all :)
The cumulative cross-section of the intakes comes out to ~110 square centimeters, about 2% less than the cross-section of the 120mm fan on top of the heatsink (in actuality, the intake will probably have a larger cross-section once you take into account the fan blade volume and hub/spar volume... of course, then you also have to look at the mesh bracing volume.... at any rate, they're basically equivalent). In the ASRock Z77e-ITX, the power plug is on the front of the build; since the front panel will have no mesh, but will be solid brushed Al, the ATX plug won't interfere with anything (and I'm using the stumpy samsung ram). The SATA plugs might, but not to any massive degree (same with the EPS12v), the back inlet area is basically unrestricted. I will look into flipping the PSU for a fourth compartmentalized airflow, I'll definitely have to swap the fan in the silverstone unit for the noiseblocker fan then :D
As far as case fans, most of the circulation fans are so close to the inlets that case fans wouldn't really help; the only place I could see them would be on the roof above the heatsink to keep the chimney effect going, I've got a pair of 80mm fans that might just squeeze in there. Keep in mind that scythe slim fan is a PWM unit, so if it's getting toasty in there it will just up the velocity (goes up to 2krpm).
axp-100 :D (check out Thermalright's Facebook page -- it'll be out in Early November) -- you're right, though, it's either that or the samuel 17.
yeah, the accelero extends a large way above the top of the gpu, adding about 25mm to the height of the case (making it as tall as a sugo05/06). If I want to do this, I think the only way is with the TwinCooler from Zotac.
the above being said, I could easily reverse the flow of the chimney to bring cooler air directly to the cpu... just working against convection at that point :)
updated sketchup:
- height increased to 135mm (5.14L volume)
- PSU flipped over to create 4th compartmentalized air stream
- power button moved to under video card area
- added headphone/mic jack
this gives some more room for side/back air intake (definitely greater than the cross-section of the 120mm fan now), also gives a bit more standoff between the fan and the psu.
alright. still worried about cpu cooling but i hope it works out ok! i know my axp-140 did great but that was with tons more area and a 1" thick 140mm fan attached to it. the samuel 17/axp-100 are much smaller and will have a thin 120mm (100mm?) fan. what cpu is going under there again? under heavy loads im worried it might not be enough. at the worst youll just have to downgrade to an i5 or undervolt/underclock or something so i'm sure any issues can be alleviated.
you definitely dont need many case fans. i agree that about the only possible location that even MIGHT help is on the top in front of the psu. if you make the top all mesh then i doubt any fans would be necessary at all. i have that same fan and it's going to be loud for not much air movement if you use it for a cpu heatsink. mine is just for circulating some air over my gpu vrms and memory chips and is non-pwm at 1200rpm. have you tried it at 2000rpm? im curious as to how loud it actually is.
i could have sworn it said axp-140, but i guess i was wrong. :p saw that one a bit ago, looks like a good cooler. i do like thermalrights products. it seems to be a samuel 17 but with more cooling area so it should do very well.
i didnt realize the accelero was so tall. i just assumed it used a 92mm fan, not a 120mm. guess youre limited to the twincooler then. are you just trying to buy one off someone who decided to WC their 670 or did you try to contact zotac about just buying one?
also, are you using the gold or bronze sfx psu? youre shortening the cables right?
with this setup you can just flip the cpu fan and flip the psu and try all combinations pretty easily to see which one cools best. :)
My i7-3770k is running slightly OC'd and UV'd, so it's about 82W TDP at full blast; even in the current setup (with that slim fan on an axp-140), prime95 blend + furmark 2560x1600 only gets the cpu to 49C. I guess we'll just have to see what happens :D
I'm running the gold st45sf-g 450w psu. Even at 2000rpm, the cpu fan only just-about equals the amount of noise coming out of the stock fan on the psu, I wonder how annoying it will be once I swap out the fan on the psu, lol.
As for the Twincooler, I'm trying all sorts of routes, zotac north america, zotac asia, working with forum members who live in the region, etc... If I won't see a massive drop in fps (civ V, borderlands 2, Z) by switching to a 2GB card, I'll just go ahead and order the Twincooler version from Asia and have it shipped here (and sell my 4GB card on the forums).
Looking at this design more, I think I'm actually going to put it on its side, with the video card at the bottom (that would make the largest dimension the height which is more aesthetically pleasing to me, lol).
Also thinking about chopping the drive area in half (so only room for 2x ssd's or one thick hdd) and rotating them 90 degrees. That would allow me to drop the front corner of the case towards the video card a bit to make the roof a little asym (again, another aesthetic change) -- the case would have some slight cues of the early freedom tower designs. Meh, can't describe it in words, i'll try to whip up a sketchup model this evening and see how it looks.
A little weird, but a ton of ventilation up top (remember, in the Z77E-ITX motherboard, the ATX plug is along the side, not up top, so don't worry about blocking the top). Ended up modifying the plan a bit from the previous post as this looked a bit better) :)
Volume of this design 4.81L.
yep, i like this more. im actually thinking about putting mine on the side too. the way i have it built the top, bottom, and right side will all be solid alu panels, so flipping it on its side would be as easy as just adding feet to the four corners to give it some airflow to the gpu. how much distance is there between the psu and bottom panel in this design? enough to fit a small fan or two as intake?
If you mean above the bottom of the chassis in this orientation (i.e. where the GPU is), not really, since most of the free space represented there will actually be taken up by the body of the GPU cooler.
If you mean between the PSU and the I/O plate, there is 40mm of space, so you could shoehorn in a tiny fan if you wanted, but you'd really want to control the voltage on it so you wouldn't get the hairdryer sound :)
For reference, according to AIDA64 Extreme, my 3770k has a package TDP of 63.89W @ 4.0Ghz (x 4 cores, i've got it at 43/42/41/40) and 1.085v (it's at -0.050v offset) during full Blend.
Just placed my order at Amazon.co.jp -- wonder how long this is going to take to get here (through a international forwarding service).
The exchange rate took a bite out of my ass for sure!
Here's a sketchup w/ some skin on the case ;)
Also moved the USB/mic jacks to the front and the power button to the back.
Still @ 4.81L :)
Nice work.. but what about an external power brick (like the 330w alienware x51), then use a riser card for the gfx? You could get it so small lol... like a new xbox size :0
any card thats more powerful than that 4GB 670 is going to make his case bigger since it will be about 3" longer. plus his card can power eyefinity at medium settings or 2560x at high just fine, no need for more than that at the cost of a huge power brick (about half as big as his computer already is) and more noise/heat/etc.
I actually looked at the x51 psu believe it or not, but the DC/DC board is the same footprint as the SFX PSU, just about half the thickness, not really worth it to me since the GPU is already of a certain height (and using a riser card would destroy temps/airflow).
In other news, the Zotac twincooler has been received by the forwarding company (from amazon) and will ship to me tomorrow! If you're trying to do this economically, I wouldn't recommend this method :p
Looks great so far!
Is the Zotac twincooler the only option for a short 670? Are there any aftermarket coolers that would fit on a short-PCB 670 and not extend past the end of the PCB?
I'm working on a similar project using a chopped SG05 and of course as others have mentioned, getting the short card is key to saving space.
So...are we going to be able to download or purchase the template for this case? That would be awesome :D
Looks great so far!
As far as I'm tracking, this is the only one. The arctic cooling ones are much taller than the gpu and need a triple slot width and the other option I looked at was an antec kuhler 620, but then the rad needs to go somewhere (and the TSA issue). Zotac is being remarkably stupid about their market segmentation, IMHO.
[edit]the AC one may actually work in an sg05-sized case if it is still full height[/edit]
Once I get to the end of this road, I will make sure others can get there more easily (whole idea of exploring, right :D)
How much bigger would the case be if it was lengthened to fit at least 9-9.25" cards?
The Twincooler is only 7" but there are not too many other powerful gpus that are that short!
Also only IMO beside the PSU (might need to lengthen the case) but there should be enough room I think for a H60 or H80...but I could be wrong.
Yeah, you could do all of those things with Case option A from Post #44 in this thread (which was shouted down as a "cop out" :p :D). If I were are large case manufacturer (*ahem* Silverstone *ahem*), I would just chop the height on the SG05 and call it a day (that would be around 8.5L). This case is trying to go a fair bit smaller though and to do that you need some specialty parts.
One good thing may come out of this, though, is that once I get my grubby mitts on the twincooler and break it down completely, there might be a way to make more of them if others are interested.
What is the case mod? I have an SG05 already :D
Basic deconstruction/de-rivet of the whole thing, shorten the front and back vertical elements to the top of the video card "tongue" opening in the rear panel, cut an opening for a SFX psu lower in the back opening (closer to the mobo). Re-rivet the beams into the new front and back and make a case shell out of your preferred material (modder's mesh, alu panel, or plexi). You'll probably want to make a custom front panel at frontpanelexpress as well
[edit]Update on the Twincooler: it has arrived in JFK, hopefully will sail through customs and be here tomorrow :D[/edit]
PO attempted delivery today, I can't pick it up until the AM arghhh! :D
Perhaps it's just me but how is cable management suppose to work in that design? Don't get me wrong it looks to take full advantage of the space that is provided but without all components represented to include potential cable routing I just don't see the current version working out for most products available. Especially considering the ideal PSU would be a modular version and those tend to have much stiffer cables than their regular counterparts.
The ATX one will go below the current SSD position to the plug (which is actually where the bottom of the ram slots are on the board in the model -- I just didn't have a model of a Z77e-itx), the pcie power will go direct to the card, the EPS power will go down and then back under the psu near the video card.
It's the SSD power that is really throwing a wrench into my plan, it will block a lot of the intake air. I'm kicking around the idea of making the case about 15mm taller and moving the SSDs back above the PSU (the power cables would then just tuck right up to them). This would also enable more intake from the front of the case... dunno if that would destroy the look of the front though.
Obviously, all of the cables will be custom sized modular ones to minimize blockage on the intake. I've got handfuls of each type of modular plug, so I'll probably use a drill bit / router bit to open the sides of the various channels and make sets of 90-degree power plugs to make things a little nicer.
At any rate, lots of stuff to test fit and work out -- the fun should begin this afternoon once I pick up the new video card!
and color me impressed: it beats out my evga 670 4gb in furmark @ 2560x1600 (2xMSAA) by about 4% (it's clocked slightly higher, about 20mhz core and 100mhz ram) with a temp that is a couple degrees cooler, too!
