Nobu
So I took a test for a Camera Technician job working for the city, and it made me realize I don't know jack about networking. Well, I was pretty sure for most, but there were some questions I definitely guessed on.
What's a quick and effective way to get spun up on network admin concepts and troubleshooting techniques? I probably won't be hired this round, but I would like to be prepared if the job comes up again and they call me.
(Edit: I looked it up and I correctly guessed that the unique 48-bit address that identifies a device on the LAN is the MAC address. +1 on my score! 🙌)
Not sure about quick. If you're willing to put in a little time, many community colleges offer courses. Many are Cisco-created and sponsored CCNA. Decent chance the teacher is knowledgeable (most of the ones I had were teaching as a side from their normal networking-based jobs). There should be al least a virtual lab available, if not real hardware. When I did it some years back, the 101 course was all the basics (IP addressing, subnetting, the OSI layers, etc.)
Ever take any udemy courses, know if they are good?
in addition to all other suggestions ( whoops sorry for late reply)
you can learn a lot with command prompt, pings and tracrts at least as far as your ISP and local area works.
Outside of that the links and books here are good, and take a dive into reading /learning about winsockfix programs /windows app.
Also I had a lot of fun in windows firewall checking out all those settings and how it interlated to those programs and connections.
Also, get a Ethernet to USB converter, PCI or PCIx ethernet card for back ups and emergencies. Less learning networking and fixing/preparedness.
Get a Network+ book, then go take your test and get the certification. Then you will have the basics. Its a good start I did decades ago.
You could also pick up some cheap network gear to play around with. Learn by doing. Older used commercial switches and routers, 3rd party firmware on (used) consumer routers, or just run stuff in VMs and not even buy hardware. There's even low-end commercial stuff you can get. Like Mikrotik will sell you a Hex Lite for $40. It's slow, but it supports a whole lot of router features you'll never get on consumer stuff.
