Network pics thread
/usr/home
Wouldn't call those giant bins... We put our junk into gaylord containers(yes they're really called that) 48" x 40" x 36" boxes
I'll take those Cisco switches if you are just tossing them lol.
MrGuvernment
Wow. Just... Wow.
That's some unbelieveable work right there. Hope they never have to change it but man, I have cable envy.
that is nuts, imagine running every cable to make sure it is on the same line all the way through the bundle and not crossing over any other ones and getting it just right!
be interesting to watch someone do this to see how they keep things together and clean.
D-EJ915
I'll take any PC100 or PC133 ECC dimms larger than 256mb you can find lol.
On a different note I migrated my zimbra server to a new box today. It was a pain in the ass because centos sucks but I figured it is the "most supported" of the ones I would use...
omegatotal
I was thinking about that, they probably measure out the longest run per group then pull and group the cables on the ground, or in a facility, then run them with a few feet extra loose at the patch end.
then its just punch down at the endpoint and do the final cleanup and punch at the patch panel, which may have something to do with them not being labeled like some are complaining about
Berg0
I'd be interested to see what the other side of the racks looks like, no switches in any of those, some long patch cables...
Macco
I'm guessing w/ something like this. Plenty of other companies out there make them as well.
mikeblas
[H]ard|DCer of the Month - May 2006
It'll look like ass, I'm sure. It seems very unique to have so much space in a data center dedicated to U-racks of patch panels. No reason to have that on the expensive floor, but someone decided it was the right design ...
There are racks that will hold boxes or spools of cable and make it easy to pull eight to twelve runs at a time. The runs are pulled this way and left long. They're terminated on one end arbitrarily, and then identification equipment is plugged into the panel on that side. The cables are identified and terminated in the target panel and the overage cut off to leave the neat runs.
calvinj
Well I meant to post a teaser thread that but that didn't work for shit.. So here's all of it :D
thefordmccord
Just figured I'd post up some pics of some old crap that we sent off to the recycling center today.
Goldpc
My home network is running for soms time now.
Pictures are on the site of the data center and data center@home
http://foto.steambay.eu/DataCenter/
Isp connection
Cable 120/10 down & up
VSDL 40/3 down & up
Switch
Dell 5324 24 port gigabit
Tp-link 24 port gigabit
Nas01
Case Norco RPC-2208
PSU Zippy/emacs P2h-6550p
Motherboard Asus P5G41T-M LE
CPU Intel® Core™2 Quad 9550
RAM 4 GB DDR3 Kingston Valueram
Controller Cards Areca 1222
Hard Drives 8x WD20EADS 2TB Raid5 2x ST9320325AS 320GB
Battery Backup Units APC Smart-UPS 750VA
Operating System Openmediavault 0.3
Nas02
Case DS211j
PSU 100V
CPU 1.2GHz
RAM DDR2 128MB
Hard Drives 2x 2TB Samsung HD204UI raid 0
Operating System DSM 4.1
Nas03
Case Chenbro ES34069
PSU 120 watt
Motherboard Itx Mobo
CPU AMD Athlon 64 X2 5000+
RAM 4 gb ram Kingston
Hard Drives 4x 2TB Samsung HD204UI raid5
ESXI01
Case Norco RPC-2208
PSU Recom 850 Watt
RAM 8 GB DDR3 Kingston Valueram
Hard Drives 4x Samsung HD204UI
Operating System ESXI5
ESXI02
Case 4U Oem
PSU Enlight 350watt
Motherboard Gigabyte p41
CPU Intel® Core™2 Duo E6300
RAM 8 GB DDR2 OCZ
Hard Drives 4x 750gb Samsung f1
Test01
Case Hp360 g4p
PSU 450watt
Motherboard Hp oem
CPU 2x dual xeon 3.4GHZ
RAM 8 GB DDR2 ecc
Hard Drives 2x 72gb 15k scsi
Operating System Debian 6
Web-02 colo backup @ home
Case 1U Super mirco
PSU 450 watt
Motherboard msi 939
CPU Amd Athlon 3700+
RAM 4 GB DDR1 kingston
Hard Drives 2x 160gb raid1
Operating System Cent Os 5.8
Web-01 colo @ Serverius in Dronten
Case 1U Super mirco
PSU 450 watt
Motherboard Supermirco
CPU Atom dual core 1.6ghz
RAM 4 GB DDR2 kingston
Hard Drives 2x 250gb raid1
Red Squirrel
I remember when those were considered new and being deployed. They were awesome. Users were so happy to get a faster computer and they were a dream to manage because of how easily they opened. :D
pwrusr
Many of the earlier clam shell dells suffered from the capacitor plague. :(
MikeTrike
I haven't posted anything network related in a while. So here's an updated cage shot with our snazzy new banners. :)
Benzino
This was the core networking in our server room prior to a rewire. What equipment we used changed as net admins came and left. Alcatel, Cisco, now going all Juniper. Not that it matters anymore, we got bought and all of this is getting yanked out. :(
USF-Nealio
At least it's a good excuse to clean up.
haunter
where do I go to dumpster dive :D
impressive wiring in back
power strip looks a bit cheap tho :p
whats the small white box on the right side in teh back of rack pictures?
mikeblas
Why did you chose PaloAlto? They don't seem to be a consumer-friendly company, so a PA-200 for home use is a bit curious.
QHalo
I'm not using it in a consumer context per se. We'll be using them for testing policies and testing management from Panorama with our PA-4020's. A few of our executives will be getting them so we will live with them as well since we have to support them. Sorry to break you guy's hearts, I didn't buy it myself. :p
dashpuppy
The through put on that unit is really low.. good thing you didn't pay for it.. :D
/usr/home
100Mbps isn't that low. It's also (most likely) their entry-model. Sure you can get $100 cheapo home-grade routers that push more, but they also suck and don't have nearly the same amount of features.
