What dimm size max does it take?
Woah that's awesome. Would make an awesome VM server.
It will take 8GB sticks
This is one of several just like it used for VM-Ware hosts in my environment.
Wouldn't it be better to have less ram stick's and more mem per stick ?
Had to change out some bad ram on a Cisco UCS blade tonight that has been throwing errors all week. Gotta love late night maintenance. That is what 196GB of ram looks like Fingers crossed that it does not happen to my other blades.
That's one of the cases when the lights out functionality of "this stick is bad" comes in handy haha.
I should snap a picture of our new 620 HP blades that have 256GB of ramOMG
Good luck with that!
Also we are testing an IBM chassis and blade that has 230GB of memory
I was just about to ask, HOW do you know what stick was bad
He can just replace them all and send the old ones to me, I'll try to find the one that's bad and send it back "its this one!".
I put them on my keychain good for scraping the window when it's frosty,
I think i still have my 30pin 1mb stick from my first 486 LOL!
The person who posted from this site gave what may be the best answer possible: his equipment provider required the ground leads to maintain warrenty. I'm going to go out on a limb here and suggest he probably wasn't the power/grounding engineer responsible for designing this installation - so I don't know why you would expect to get an answer better than that one.
And re-read your posts. They do appear to be quite hostile and derisive. You might not have intended that - but they are.
How interesting! I didn't know that Motorola installed the external chassis grounding leads on your HP switches. Do you know why they did that?
My HP's have an LED for each stick of ram on the front of the chassis to display which one is bad.
Dell tell you exactly what stick on the little LCD on the front.
OK, a nice little addition.... thanks to Dash for the prod in the right direction...
QNAP TS-419U+
Slow, but getting there....
Still got some general tidying/cleaning up to do and need to change those "patch cables" out, but it`s functional, or rather it will be when those disks have sorted themselves out...
Quick question for you folks who install network drops/ect.
Where do you order from? I have a Panduit 2 post rack + cable management already, but I need several 24 port patch panels, several hundred patch cords, and some other misc parts. Monoprice.com is just too cheap for this situation (I need Cat6/Cat6a cert gear and I just do not trust Monoprice equipment.)
Thanks!
Going to start adding my servers when the rails show up
Nice rack Dash, I'm looking for something similar, maybe a little bigger.
And geezus, 98GB of ram? How many virtual servers running on there?
We run virtual at work, my boss gave my a better idea on how they actually work, he's going to take me up to the server room and show my at a later date too.
what brand were they? just in house crap, or what?
The Dell cords are always super thick and long () We never use them.
