Spyder- you are living my dream, I would love to do that for a living...
If you enjoy doing it, then you wouldn't want it to be your main job. After a while, it becomes a pain in the ass.
...which begs the question: Whats the most RAM you've ever seen in a server?
It was in our SPARC server that ran the oracle backend for 4.3 million customers:
32 4-core processors 2TB of RAM. It was a freaking beast.
But it was only 16GB per core...
Wow, that's a crazy server.You could put Citrix on there and publish Crysis as an app.
I spent the evening upgrading our pool to XenServer 6.0 + all latest patches. We were running on 5.6 for quite some time.
I see pidginshit![]()
Xen, looks pretty sweet, how you like it compared to hyper-v 2008r2..
I'm been debating on Xenserver free or Proxmox as my next solution for home. Xenserver does look pretty nice, even the free version offers quite a nice set of features.
Not a great start- just installed Xenserver 6 and rebooted and it's hung on the white bootup screen :-/
What hardware are you running it on?
I would assume that's fine, though I've never did a flash drive install before; I'd think it would behave the same. Latest stable board bios, etc?
SuperMicro X8SIL-F w/ x3470 and 16GB RAM
Installed XenServer 6 to 16GB USB flash drive
where did you find the iso to install this from or with ? I looked ( quickly ) but didn't find it.
Yup. I have another identical server but not sure if the flash drive in it is big enough so I might have to get up to install a larger one![]()
and this free triial never expires right ? it's just limited to hardware and stuff ?
I have quad core xeon and 32gigs ram.. and hope to use iscsi for my vm's to live on..
I think you still need to get the "xen free" license by signing up for free. It expires every 12 months, because that's how they roll.
Took some pictures of my 2 newest rackmounts: Dell Poweredge 2950 III and Fujitsu RX200 S5.
2x E5440 2.83GHz
8x 2GB PC2-5300F
1x Sandisk Cruzer 4GB /boot
2x 73GB 15k SAS RAID1
4x 1TB 7.2k SATA RAID5
1x Intel Pro/1000PT
1x Perc6/i - backup battery needs to be replaced though.
Bought the USB because I thought I might use it (ESXi or whatnot) but ended up sticking something else on it and figured I may as well still use it for something.
Fujitsu RX200 S5
2x E5530 2.4GHz
6x 4GB 1333MHz ECC Reg
4x 300GB 10k SATA RAID10
1x Brocade 825 8G DP FC HBA
extraneous iBBU which I don't need
virtual media
typical rack server loud but not SUN loud (i.e. deafening). If you have all 8 DIMM slots in the 2950 filled it will not let it go into quiet mode but it is still not full blast. I think the RX200 is quieter and less annoying to be honest but it has been a few days since I had the 2950 powered on.Are they quiet ? I know the 2950's 1's and 2's were loudbut not sure about the 3's..
I work on them all the time but they are in rack enclosures so i can't tell if they are loud or not.
The Fuji;s look nice..
My asus is SILENT hence why i bought it.. (silent after new bios revision installed and turned on smartFan II )
MikeTrikejust installed xen, im actually liking this
Question tho,, how would i convert or get my 2008r2 hyper v vm's into this ?
Download XenConvert, works great for Windows Guests. You can also import most .vmdk and .vhd's into it, I've had fairly decent luck with it.
But as for XenConvert, you install it on your guest VM that you want to convert. Run it in there, make sure it has "work space" within the guest you put it on to do the conversion and send it over. I think you can also use shared drives/folders to use as a work space.
wonder if that works for debian then ?
Can xen, import a hyper v file ?
having problems, or trying to figure out how to get the local hard drive to install and be used for storage right now... I have a 250gig sata drive in the computer but not able to use it for storage.. only see's the 8gig usb stick that xen is installed on....
As prommised![]()
Hrere is my new Qnap 410U, bought from MikeTrike, THANKS FOR THE DEAL!
has 4 x 1tb 7200rpm drives, came with rails. Just updated the os on it, and configured it for raid 5 + hot spare..
Soon as hdds come down ill migrate all 4 hard drives to 7200rpm 2tb or 3tb drives.
Pics.
