I have a friends pc running Windows Vista Home Premium and the network connection will not work inside Vista. The hardware is fine I have tested it from bootup. I have booted up with Kaspersky and Bit Defender AV boot disc and updated boot of them with the network connection and they both scanned the whole computer and found nothing. I have also used ComboFix and the problem is still there.
The network connection icon of the taskbar shows "The dependency service or group failed to start". I have looked under Service in Admin Tools and don't see anything there that I can tell this isn't running that should be. When I right click on the network connection icon and select "diagnose and repair" I get "network diagnostics cannot run because the diagostics policy service is not running" When I try to start that service I get an Error 5: Access is denied.
In the Event Log, I am seeing some error with the DHCP and all of them have say "the DHCP Client is shutting down. The following error occurred: Access is denied"
Anyone got any suggestions?
