goodcooper
- Nov 4, 2005
i've come late to a deployment of security cameras at a number of locations by a local security company...
said security company seems shady and unwilling to support the REEEALLY crappy DVRs they installed... these DVRs drop cameras on a regular basis, AND if the cameras stay up, the web interfaces are atrocious, require IE5 w/ 0 security settings, and when you DO go through and set up the security correctly, you can't dump footage or do anything, just INCREDIBLY buggy...
so my options seem to be as follows:
expensive and not that great of a return: get expensive coax interface cards and put servers in
hardest, but best value with great return: rip it all out and get with the system and get some network based ubiquiti cameras... would also need a low power storage server to run the NVR, we're talking 12 locations....
cheapest and easiest: find a coax DVR with a working web interface that doesn't blow...
tried a vonnic from newegg, also one from monoprice... same deal... but at least it seems to be recording.... try to access it remotely and forget about it...
do you guys have any suggestions on a decently priced network-enabled DVR? would need a few 16 camera ones and some 8 camera ones... strongly prefer one that uses established browser standards instead of archaic activex controls that don't work worth a darn... OR even just a add on program that is reliable, doesn't have to be browser based...
