Double Jesus
- Jul 24, 2002
ok, i ordered this from newegg and love it so far (currently at 2475 on my 3000+ venice 275X9) except for a few things.
1. I didn't get my d bracket or firewire ports with it... it looked like the box was opened before and instead of a dbracket i got this:
what the hell is that for?? and WHERE'S MY DBRACKET?!!
not such a big deal ok... but the last neo plat (neo2) i got came with them. does newegg take them out or something? last one i got from ncix here in canada.
2. I can't get the digital out to play through all my speakers. when i use a coax cable and plug it in and use the digital out, i only get sound through the front left and right. I have logitech z680s and they should run the 5.1 just fine. If i use the non digital cables, it works just fine. Does anyone know how to fix this? i have it set to 5.1 in the control panel thingy, it just doesn't work. I had a similar problem with the neo2 plat i had, except it worked with 4 speakers. Do these cables go bad easily or something???
thanks!
thanks!
