Nehalem i7 Build Log (56K Warning)
jonneymendoza
2009 Nehalem i7 Build Log 16-18th January 2009
During the weekend beginning from the 16th of January , the old Pentium 4 built inside a chieftec matrix case was about to be replaced by a new machine altogether.
The specs of the old machine are as follows:
• ABIT ice-7 pro Socket 478 Mobo
• 2gb DDR Ram
• Nvidia 7800GTX AGP Card(i had a ATI 9800gtx before)
• Intel Pentium 4 3.2ghz northwood
• Seasonic 450w PSU
• Chieftect full tower Matrix case
The specs of the new pc are:
• ASUS P6T deluxe Socket 1336 Mobo
• 3GB DDR3 Ram
• Nvidia 260GTX card
• Intel i7 920 2.6GHZ Nehalem
• Seasonic m12 600W PSU
• Lian LI full tower PC-A7010 case
• Thermalright Ultra Extreme aka TRUE
• Enermax 120mm fan.
As you can see, this is a major upgrade for me and one i have enjoyed building over last weekend. Enough talk, lets see some pictures !!
This case is a monster. Just look at the size comparison between the case inside the box and my 360!
More pics of comparing the size of the case alongside the 360.
Christmas came late for me :)
The Brain of my new pc
The memory
Nice looking mobo!
This cooler took AGES to install!! A nightmare if you don’t know how to do it first time!
Installed in the mobo tray
Look at the size of that card!
No hard drives?
Old vs new
My legendary pc!! It has served me well for the past 5+ years. As you can see i modded it and cut out the side panel myself using a electric jigsaw
All up and running :)hows my cable management lol
All done..
worklog? i wasnt aware of that section, if it exists can someone please move this thread there. thanks
Well for one thing try to reroute your cable to the back of the motherboard.
Get some wire straps to group your cables together so that they don't flail around.
And basically try tucking them in behind stuff like your PSU. Will do wonders to your temps.
i'l need to get an extention lead for that PSU 24pin mobo connector as it is too short to be routed at the back of the mobo but as you can see, i only have the sata cables and front usb cables showing in the above pics :)
