Little Grabbi
- Aug 15, 2003
So here's tha plan. I hook up a normal, run-of-teh-mill watercooling setup, but with a valve on top of the res. The res would be a bay res, 2 bays high, and about half full. An air pump would be attached to this valve, which shuts off at -5 PSI.
The idea is to eliminate leaks by negative pressure, so only air can get in, but water can't leave. Think I should do it?
