depends what you want to do with it & what you are using it for.
The abit has far better hardware/fan monitoring & control, an LED POST reporter, firewire, eSATA & Intel RAID on the ICH8R.
Clock for clock performance over 400fsb will also be better than on the Gigabyte as it stays on the 1067 strap rather than switching to the looser 1333 like the Gigabyte.
The Gigabyte is cheaper & will hit a higher fsb when overclocking but has far fewer features.
If you are getting an E6600 or faster I'd say it would be fine, otherwise get the Asus Commando, it will let you FSB OC like crazy (I'm an OC chicken -and on aircooling, so I have stopped at 400MHz FSB).
P5WDH is a bit of a jump in budget up from a DS3/AB9 Pro.
As already said if you have an E6600 or above it will be fine (975X afaik is till the bst performance clock for clock but doesn't hit as high fsb).
If you do look at a higher end 965 I would recommend the abit AB9 QuadGT over a Commando.
I have a P5W DH paired with a E6600 and it's been running 3.3Ghz (367x9) for the past 6 months or so with no issues. I'm interested to see what Bearlake is like, but I can't imagine that DDR3 is going to be cheap right away.
Looks like the early versions of the bearlake boards are going to use ddr2. Of course I ordered my quadgt 6 hours before the bearlake boards were released. But I think I'm going to be very pleased with the qgt though.
well i went ahead and bought the ds3 because i dont have a core 2 duo yet.. and i dont have water cooling... if i decide i dont like it, i can just get another one... plus it is the newest rev. so i dont know i am going from a msi p965 platinum for the ds3 so i hope i like it.
