Soochinator
- Jul 11, 2017
I'm finally getting ready to set up a very small HTPC to manage my digital library. The system I'll be using has a DisplayPort output capable of 1080P (but not 4K) that will be used to connect to my TV via a DP to HDMI cable. The system will have an internal 1TB HDD and also access media on my 4TB NAS. It will have 4GB DDR3 RAM. The CPU I'm planning on using is the Pentium G3260T.
My question is whether the Pentium G3260T will be capable of streaming 1080P content without stutter or other issues. Do any of you forsee issues with this type of basic setup? If the G3260T isn't adequate, the i3-4160T, 4170T, 4360T, or 4370T are what I have in mind.
Thanks for your input and insight.
Edit: forgot to mention the OS will be Win 10 initially, but I would like to look into dual boot with either OpenELEC or KodiBuntu although I haven't done enough research to know which option yet.
