misteroptimist
- Jul 28, 2011
1. What will you be doing with this PC? Eventually light Gaming, Adobe CS5 Suite, Pro Tools, 720p video editing
2. What's your budget? 750 MAX
3. Where do you live? No places to buy in store. I'll purchase off new egg and amazon
4. What exact parts do you need for that budget? Case, CPU, RAM, Dvd drive, hdd, motherboard
5. If reusing any parts, what parts will you be reusing? I already have a beautiful 27" asus monitor.
6. What specific features do you need in a motherboard? Nothing super specific, i just need this puppy to edit 720p videos.
7. What resolution output do you need? 1080p
8. Does this system need to fit into a particular space? nope
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)? Not comfortable, i just need something easy
10. How important is the noise/silence of this sytem? It doesn't have to be absolutely silent, but doesn't need to sound like a plane is taking off in my room
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc? I need to be able to take it to work and back home everyday. So something pretty portable. I figured going with a SFF build that would make it easier.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards . Yes, I have a 64bit copy.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years? Within 2 weeks.
Here is kinda what I had in mind. What do you guys think? Long time lurker here and just excited to get the best build for my money.
Case: SilverStone SG05 http://www.amazon.com/SilverStone-S...Q1C8/ref=sr_1_1?ie=UTF8&qid=1311885033&sr=8-1
CPU: i5 2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Mobo: H67M
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157239
Ram: G.SKILL Ripjaws Series 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Dvd burner:
http://www.newegg.com/Product/Produ...17075X740592Xd64433f98425e99a949787411bac856a
HDD: Western digital 500 gb
http://www.newegg.com/Product/Produ...17075X740592X41bee15a0954f8b52f473953eba5a1c4
CPU: i5 2500K
Mobo: H67M
Dvd burner:
