Need upgrading help
jybgess
I’m going to try and upgrade a desk top for my son. I don’t want to spend money and have someone do it for me. I want to upgrade a Q6600 to an i5-2500. I know I need a new Mobo and ram. I want to keep everything else the same. I never did this before. Could some one explain step by step how to do this. I feel confident about disconnecting everything and removing the Mobo. I know I have to install the new processor, add the thermal paste, put the heat sink on then reconnect all the wires. Do I have to re-install windows 7? Do I have to save any files? I want to give my son this computer so I don’t care about losing junk I had on it. If you could break it down to me like your talking to a second grader, that would be great?
If everything works out, will I get a message or something that will tell me to update drivers click here?
Any advice on how to apply the thermal past?
In the Gen[H]ard FAQ, there's a ton of PC Building Guides linked. Those should be more than enough to tell how to replace a mobo, install a CPU and RAM, etc in a PC. You probably won't have to reinstall Windows 7 due to Windows 7 being pretty great at being transferred to and from different hardware.
If you want advice on what hardware to buy, please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
