hello, i haven't posted here in a few years so i guess my old acccount was deleted
looking to upgrade my PC and need advice on a motherboard
currently using:
ASUS P4T533-C mobo
1GB 1066 RDRAM
2.53 P4
geforce 6800gt (AGP)
2 80gig 7200RPM HDs
i'm looking for something that I can reuse my gpu in, but i am up in the air about what CPU to get. I was also looking to buy this ram strictly based on the price/performance value (going for 2GB)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
is DDR the best thing out there now? i know a little bit about dual channel mode but do you need a certain motherboard to support it? also, what's the difference between the 240pin DDR2 and the 184pin DDR?
basically i need some serious advice - i've been out of the game for awhile and am a little bit overwhelmed by all the new stuff - looking to spend appx $400-500
currently using:
ASUS P4T533-C mobo
1GB 1066 RDRAM
2.53 P4
2 80gig 7200RPM HDs
