Need to replace wife's XP box
Milehigh
Hi all,
Of course since it is XP, it needs to go... here are the questions:
She is strictly an email, surfing, shopping kind of woman. Nothing fancy, no fancy graphics, etc..
I'd like to stay under $500 if possible.
I'm in Colorado, Denver metro area
Would like a cheap box, mobo & cpu combo with 8 gb of memory, video built-in is fine. Would like an SSD around 120 to 240 gb. Small power supply, whatever is sufficient. Interested in dual monitor support.
Only thing I'm reusing would be a keyboard, mouse, and monitor though I might upgrade that later.
6) Will you be overclocking?
No
22" is the current monitor, due to usage above, 1680 x 1050 is fine, anything higher is just a bonus
As soon as I put together the parts, next couple of weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Onboard video is fine, but dual monitor support preferred.
Whole point is to move to a Win7 64 bit platform, away from XP, so need to buy Win7 64 bit. I'll worry about Win 8 later... combo deals are great from reputable vendors (IE Newegg), and the box esthetics are important to my wife, she likes small and black I think :)
Here's what I came up with. Has almost everything requested (no dual-monitor off of board that I'm aware of) and went just a bit over budget ($522.12).
http://pcpartpicker.com/p/3mZ6s
You said she likes things "small and black", so I spec'ed out a mini-itx rig using a black coolermaster elite-120.
Not bad, thanks for the spec'd list Mogar... definitely some good stuff on there that will meet her computing needs.
Thanks wtourist, was the 3rd item down a cpu? Didn't load, do like the Cooler Master box :)
