Need to replace my 8800GT
merc141
Wanted to upgrade my current 8800GT to something that will last through the lifetime of this system. My primary concerns are that I don't want to replace my power supply or break my bank. About <$200 or so, I was also wondering if now was a good time to get a card or if I should wait and see if I can save some money.
Q6600
4GB GSkill
Corsair 520HX 520W
Abit IP35V P35
I was looking at the 5770 and 5830, I am not sure how those 2 compare with each other performance wise. BTW I am at 1680x1050
Might wanna also consider a used 4890 from the FS/FT forum here.
You should be able to find one for about the price of a 5770 and it'll perform about the same as a 5830.
You'd only miss out DX11 and probably lower power draw.
Edit:
Oh and all three should work fine with your PSU.
I ran my 4890 with a 550w Antec.
Im pretty much in the same boat, 4gb q6600 and i just went for the 5830 that ClearM4 linked, figured the 5770 wasnt enough of an upgrade for me to warrent the cost,and the 5850 for 310+ is too much for me.
He would also miss out on the warranty if he was to buy the card used. Unless it was a XFX card though.
