need to build new pc
shetu
Photoshop, few vm host
700$
Bangladesh
cpu = Intel Core i7-4770 Processor 3.4 GHz(4th generation, Haswell)
mb, ram, psu
casing = Corsair 550D, h100, monitor
6) Will you be overclocking?
n/a
21 inchi (1080p)
next 3 / 2 month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
sata 6gb/s, vt-d support
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
yes, winxp 64bit
In my country these are favorite on pc user
gigabyte gigabyte z87 hd3
gigabyte Gigabyte z87 ud3h
gigabyte Gigabyte z87 G1 sniper M5
asrok Z87 Pro3 Motherboard (4th gen)
asrok Z87 Extreme3 Motherboard (4th gen)
asrok Z87 Extreme4 Motherboard (4th gen)
asrok Z87 Extreme6 Motherboard (4th gen)
Corsair Vengeance- 16GB Dual Channel DDR3 Memory Kit(2x8GB)
Corsair RAM Corsair Vengeance Pro Series 16GB (2x8GB)1600 bus (Silver)
Corsair Corsair 16 GB(8*2) Dominator
What about the case and hard drive?
As for the RAM, can you list the model number of that first RAM set?
i have samsung 2Tb and Corsair Corsair SSD Neutron GTX CSSD-N120GBGTXB-BK 2.5" 120GB SATA
please see the link for ram model. i do not find exact model number from this website.
