System:
CM Sniper Case
MSI GD-65 P67A B3 Motherboard
i7-2600k Processor @ 4.8ghz, 1.37 vcore
8gb Corsair Dominator GT 2000mhz RAM @ 1866mhz
ASUS ENGTX570 (the one with the tri-slot cooler)
Want to do:
I have the ZALMAN CNPS10X air cooler, and my temps on my i7 2600k is 36° idle, and 70-75 full load on core #2 and #3, the other cores are a little under 70. What I am wanting to do is to get the CPU down as low as I can get it under full load. My dilemma is that I have only had experience with the Corsair H50 which turned out to be a joke since air coolers did a similar job. I am new to doing a manual setup (tubing, pumps, rads) as far as the best for what I want to do.
As you can see, I would like to water cool the GPU as well.
I have been through the sticky at the top, and it lists the inexpensive way to water cool things. I don't really want to skimp out on anything money wise if there is better parts.
Thanks!
CM Sniper Case
Want to do:
Thanks!
