HaMMerHeD
- Jul 13, 2004
I am revamping the storage configuration on my fileserver, and I need some help. I am not a storage expert by any stretch of even the most robust imagination. Yeah, I know about software RAID and hardware RAID and the basic crap like that, but not knowing what kind of hardware is "good" for what I want, I am looking to you peeps for guidance.
Here is my problem:
The existing storage solution on my fileserver is inadequate. It is too small, old, and does not offer protection for all of my data. I first put it together about 3 years ago, and it had 3 hard drives in it. There is a 160GB EIDE system disk, and two 500GB EIDE data disks which are set up as a single mirrored volume using Windows Server 2003's built-in software RAID functionality. So between the two 500GB drives, I had 465GB of protected storage. A few months after that, I added a 400GB SATA-II drive, but it is not redundant.
Fast forward to now, I am running out of space, and the storage I have is slow.
Here are my goals for a replacement storage system, in order of priority:
1) more storage (at least 2x)
2) 100% protected data storage (but not OS)
3) $500 budget
4) better performance
5) lower power consumption
My proposed solution looks like this:
Hard Drives: Samsung EcoGreen HD103SI 1TB SATA-II
Drive Bay Module: American Media Systems DS-3141SSBK 4-in-3 SATA module
RAID Controller: Syba SY-PEX40008 PCIe SATA-II Controller
The hard-drives are 5400rpm drives. I chose these drives for a number of reasons: First, they are cheap at $75 each. Second, they do not go into unresponsive recovery modes when idling like some cheaper WDC drives, so they are actually usable in a RAID configuration. Third, they use less power than the drives I have now. I am hoping that the possible performance increase from running them in a stripe will make up for the lower spindle speed. I don't need it to be blistering fast, but I also don't want to be waiting on it.
The controller card uses the Silicon Image SiI3124 chipset, which I have come to believe through my research is well-supported and stable. I am not married to this choice, so if someone has a suggestion for another PCIe card for a similar price, I'd love to hear it.
The drive module is pretty generic, and is basically just a set of condensed hard drive racks. It places four 3.5" SATA-II drives inside three 5.25" external drive bays, which is precisely what my server's tower has available. (It has 4 bays, but one is taken by the optical drive.)
As for a configuration, my plan was to make it pretty simple. All four 1TB drives would be configured in a single volume RAID-5 array. Based on my research, this should give me ~2.8TB of usable space with single-drive fault tolerance. I currently have a total of 965GB of storage, and only 465GB of that is protected in any way. So this will give me about 3x the storage I currently have, and improve my fault tolerance.
Any comments or suggestions? I'm not married to any of these choices.
EDIT:
Looking more at reviews of basically all inexpensive SATA RAID controllers, it looks like OS/software RAID is going to be my best option, unless I want to spend another couple of hundred dollars on a proper disk controller. Does that seem correct?
Here is my problem:
3) $500 budget
EDIT:
