I just have a few questions that are pretty narrow but I'm hoping someone can answer:
1. Motherboard - I'm trying to decide between the Asus P6T and P6T deluxe. I'm kind of on a tight budget but I'd pay the extra $65 if it was really worth it. This is mainly a gaming system, and the primary things I care about are flexible GPU options and being able to tolerate a moderate overclock for a couple of years without the board dying. If overclocking/reliability will be pretty similar, I'll go with the cheaper one since I don't think I need the deluxe features.
I was also thinking about this Gigabyte but I don't know a lot about it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128374
The price is right and the old gigabyte board i got when core 2 duo launched served me pretty well.
2. Memory - what speed should I expect it to run at? is the DDR3 2000 useless because nobody runs it that high? I need to know the fastest memory speed that would actually be practical to use. The reason for this is that with the mods I run, Oblivion is actually memory bottlenecked. At the bottlenecked parts, I had a 1:1 speed increase when I upgraded my DDR2 from 800 to 1066, but they still run crappy. I'd pay extra for the RAM to smooth this out because I play oblivion a lot, but again, I'm on a tight budget so I don't want to buy something faster than I can actually use.
3. Cooling - are the brackets the same from 775 to the new socket? Can I just pop my Arctic freezer 7 pro onto the new mobo?
