need some RAM help here
sinplicity
Ok just built my system with a MSI K8N Neo4-F Socket 939 NVIDIA nForce4-4X ATX AMD Motherboard , Patriot 1GB 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory X 2
The mobo isn't reading it as dual channel even though I have them in there respective slots, also it shows them as 333 not 400. How can I fix this? Thanks a bunch.
ok magically postimg as 400 now. But the dual channel thing is really pissing me off. Yes they are paired, yes they are in the right slots (I even moved them through all the other slots) Am I missing something in the Bios? The guy is comeing by at 1pm to pick this pc up and I am stumped PLEASE HELP!!!!!!!!!!!!!!!!!
The same thing is happening to me with a MSI 875P board I'm using. I can't figure it out for the life of me. Runs fine in single channel, but dual channel automatically drops it to DDR333 speed.
ok got this fixed but it doesn't make sence. I oc'd the mem to show a bit higher then 400 then booted up shut down returned it to original settings and it showed as 400 and dual chanel. This makes no sence but hey it all works now .
