Need Some Help With this NEW PC
isaac27
This New Pc (for my Friend) Need to Be
1. "Budget PC" (but still be good !)
2. Not For Overclocking
This is My ring -Please Leave your note , thanks isaac =]
1. CPU: AMD Athlon 64 X2 5200+.................$130
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
2. Mobo: ASUS M2N-E.................$95
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131022
3. Memory: Kingston 2GB (2 x 1GB) DDR2 667 (PC2 5300) Cas-5.....$72.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134046
4. Hard Disk: WD 250GB 7200, 16MB SATA.......$68
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701
5. Video Card: SAPPHIRE Radeon HD 2600XT 256MB 128-bit GDDR3......$100
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102700
6. DVDRW: SAMSUNG Black 18X DVD+R ..........$30
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151133
7. Case: Antec NSK4480 ATX Mid Tower Case+380W Power Supply......$85
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129031
Total: $581
Thank you a lot
isaac
- What is your friend planning to do with this new PC?
- What size monitor does he have?
- What's his exact budget?
My Friends Planning to play the New PC Games Like....
(Medal of Honor Airborne, NFS Carbon, Lost.Planet, Sims2+Add-on and more)
Enjoy from Movies, TV-Episode Music......
Maybe install VISTA when Microsoft Release the Final "Vista+SP1"
Screen is 17" LCD
and the Budget is Around $600
he want to Connent the Pc to his TV so he can watch movie on a bigger screen
Well first of all, I wouldn't bother with the 2600XT. It's a really poor graphics card IMO. Go with the x1950GT for $115 instead or the $90 7600GT. Either card will be a better choice than that 2600XT:
eVGA 256-P2-N615-TX GeForce 7600GT 256MB PCI-E Video Card - $90
Sapphire 100199L Radeon X1950GT 256MB PCI-E Video Card - $115
Also why go for DDR2 667 when DDR2 800 RAM is only $2 more?:
A-Data ADQVE1A16K 2 x 1GB DDR2 800 RAM - $75
Don't worry about A-Data. They make a majority of the world's RAM so they're not that bad of a company. Oh and if your friend doesn't need all of the features of that Asus mobo, then I recommend going with this mobo instead:
Biostar TF560+ Nvidia nForce 560 Motherboard - $80
I'll Go For the :
SAPPHIRE PCI-EX RADEON X1950GT 256MB DDR3 256 BIT DVI TV/O - RETAIL
~. but it's not DX-10 Card !
& will the 380W will be enough for the Video Card ?
- are u sure that this card is stronger then the HD2600XT ?
The Memory will upgrade to DDR2 -800Mhz !
and i think I'll keep the Asus Mobo , good reviews & I love ASUS =]
Well that 2600XT doesn't even have the power for DX10 games in the first place. Right now you need something a bit beefier to actually see the differences between DX10 and DX9.
Hmm the PSU should be enough to power the x1950GT. Don't think you'll run into any problems. It's an Earthwatts 380W PSU and that's gotten some pretty good reviews.
And yes I'm pretty sure the x1950GT can beat the 2600XT. Here's a link that might help you decide:
http://www23.tomshardware.com/graphics_2007.html?modelx=33&model1=726&model2=858&chart=277
Choose any benchmark you want and you'll see the difference between the 2600XT and x1950GT.
