I'd really love to be able to play battlefield 3 in 1080p with 60fps, this is my main goal.
2) What's your budget?
Are tax and shipping included? 500
3) Which country do you live in?
Florida, USA
4) What exact parts do you need for that budget?
cpu,ram,case,gpu,mobo,psu.hdd, cooling
5) If reusing any parts, what parts will you be reusing?
none
6) Will you be overclocking?
If possible
42 inch 1080p
Now
9) What features do you need in a motherboard?
I'd like usb 3.0 but if it doesn't fit within the budget I'd be fine without.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes win7 64bit
Florida, USA
none
If possible
42 inch 1080p
Now
Yes win7 64bit
