Need some assistance with new build
jslater25
1) What will you be doing with this PC?
I plan on doing some gaming and photo editing
My budget is roughly $500, but that's flexible
3) Where do you live?
I live in San Antonio TX
4) What exact parts do you need for that budget?
I need a new motherboard, processor, ram and CD/DVD drive. I <might> need a new power supply
5) If reusing any parts, what parts will you be reusing?
I plan on reusing several hard drives (SATA, 3G/s 7200rpm) and a Radeon HD 4670 video card. I might use the power supply (Antec SmartPower 2.0 SP-500 500W) if its okay with you guys.... otherwise I guess I'll be in the market for one of those too.
6) Will you be overclocking?
No overclocking for me.
I currently have a 23" widescreen generic HP HD monitor
I'd like to buy sometime this week, but this too is flexible.
9) What features do you need in a motherboard?
Features in a motherboard... nothing is required, other than good quality. I wouldn't mind having USB 3.
10) Do you already have a legit and reusable/transferable OS key/license?
I do have a valid, legit Windows 7 Home Premium 64bit license that I will be using.
So.... Here is the hardware I'm currently looking at:
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398
Gigabyte GA-MA790GPT-UD3H
G.Skill 2Gx2 (4G total) DDR3 1600 RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
AMD Phenom II x4 955 processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
After shipping, the costs come to roughly $400. So that leaves me with a little extra to put towards either another 4G of RAM or a new power supply, depending on what's recommended/necessary.
And I think the video card is somewhat weak, but will work for now. I'd rather wait to spend $$ on the video card at another time.
*Sorry for my weak link-foo. I don't know how to make the hyperlinks work...
Your ability to link is fine, but you will need a new PSU. For simplicity's sake, the Antec Earthwatts EA650 is a good replacement that can handle any high-end single-GPU card that you decide to buy later.
The rest of the parts are fine, but if you want to cut a couple of price corners, you could take advantage of the combo deal the X4 955 has with some OCZ DDR3 RAM and swap out the motherboard for a cheaper yet still capable alternative. (That particular board doesn't have any SATA III or USB 3.0 ports, but you could easily add them in later via an add-on card.)
If you're willing to go the used route, see if you could find an HD4870 (1GB model), HD4890, or GTX 260 (216 core model). One of those three cards would be a relatively inexpensive yet notably better alternative to your HD4670 (which you could sell later).
I kinda figured I'd need a new PSU, but was hoping I could use that money towards something else...
As for the combo deal (proc and RAM), the pricing looks great, however I'm concerned about all the negative reviews. Seems like roughly half the reviews had issues with that RAM. And since its not specifically in Gigabyte's approved memory list, I don't feel as comfortable with it. If the reviews were more positive, I'd be all over it.
I can't really tell you how well or how poorly OCZ RAM will work on AMD boards. On Intel boards, most of them are no good as Intel requires RAM to run at 1.65V or lower (Intel's standard is 1.5V) for safe operation. Regardless, the G.Skill RAM that you chose earlier is a good choice. If you aren't going to be overclocking, look for a cheaper DDR3 1333 kit. Regarding the board's QVL for RAM, there are way more brands and kits of RAM than any motherboard vendor could test at any one time. As long as the RAM can run at the JEDEC standard (which I believe is 9-9-9-28 at DDR3 1066 speeds), it should be fine for your board. For greater peace of mind, however, look for RAM from a brand/manufacturer that's represented in the board's QVL.
Antec's SmartPower 2.0 and TruePower 2.0 PSUs have a history of failing at random times, due to the poor construction and use of bad capacitors. The newer Antec PSUs, especially those that are rated under the 80 Plus certification, are built better.
What's your long term plans with this build? Are you going to make future upgrades/purchases within the next six months?
Part of the reason for the build is due to some motherboard issues I've been noticing lately (due to my young daughter pulling the plug without shutting down... several times) on my current rig.
I don't have plans to buy additional hardware in the near future, so the main intent is to use this for gaming and for some picture/ light video editing. I also run VirtualBox or VMWare Player on the system so I can do some Linux lab environment stuff.
I figure with this hardware, I should be good for a while (I don't typically get to play the latest/greatest games when they come out).
Looks like my post was added while you were editing yours, so I'll edit my reply. ;-P
I don't worry too much about the QVL most of time, however when hardware gets so many negative reviews I tend to check the manufacturer to verify all's well.
The Truepower I and II series as well as the Smartpower series were well known for their above average death rates due to a poor choice in caps and cooling design. In more specific terms, Antec/CWT specified/used caps (Fuhjyyu caps) that did not respond well to heat. Unfortunately, Antec made the decision to have the PSU fan only ramp at really high temps in an effort to keep the PSU quiet. However, just medium to high temps were enough to screw up the caps so really high temps were murderous. Over time, this degraded the quality and performance of those PSU series.
So I recommend replacing the PSU, especially if you hear a squeal, whine, or any odd noise coming from the PSU. Those are usually the first signs of those particular PSU lines dying. So if you do hear a squeal, whine, or any odd noise, that's enough grounds to replace the PSU.
Since you say your budget is flexible, I would go with a Core i5 750 cpu build with a mobo that has the USB 3.0 you are looking for. It will outperform the AMD X4 955 in photo editing as well.
CPU/MOBO - Intel Core i5 750 + GIGABYTE GA-P55A-UD3P both for $339.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.332520
*Note: The Intel Core i5-750 cpu does not have Hyper-threading Support.
RAM - 4GB G. Skill Ripjaws for $104.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
OPTICAL - LG 22X Sata DVD Burner for $22.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167
PSU - Antec EA650 for $74.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Total: $542.95 + $7.87(shipping) $550.82
To shave some money off this cost, you can go with the Corsair 400CX 400W + LG 22X dvd burner combo for $72.98 $15 mir) w/free shipping. This should bring the total cost with shipping to $525.82. The Corsair 400W doesn"t seem much but, it has 30A on the +12v and should be enough for a Radeon HD 5770 or 5850 video card upgrade. Plus, the Core i5 750 cpu consumes low power and you're not overclocking.
BTW, that LG drive doesn't have the best user reviews and if you feel iffy about it, you can go with Sony Optiarc or Asus DVD burners. Both of these drives have a combo with the Corsair 400CX power supply.
Thanks everyone for your assistance and your suggestions. The link provided by HardwareGuru makes me have to think about which direction I want to go (AMD or Intel). I've been leaning AMD for the past few years, and haven't been disappointed by their hardware.
The $550 price tag in the last post isn't out of my range, although its higher than I would prefer. But if that upgrade benefits me more than the stuff I was looking at originally, it will be worth the extra cash.
Again, thanks to everyone. You guys are always quick to respond and very helpful.
