SuperSheep
- Dec 18, 2011
I am building a new system because my current system is nearly 10 years old. It has performed admirably and I built it with [H]'s help. My new system is based on the ASUS Maximus IV Extreme and I am planning on watercooling my CPU/GPU(s).
My build thread
I already have the waterblock/pump kit and am planning on using two 120x2 radiators mounted in the front of the case pulling air in. The back of the case will have 3 120mm and 2 80mm fans exhausting air out. My question lies in how I should route my plumbing.
I have envisioned the loop as such:
Pumps mounted in series connected to a tee.
Tee splits to input on each radiator (radiators in parallel)
Output on radiator connected to another tee going to a single tube again.
Tube from tee running to CPU, then GPU, then back to the pumps.
This way I have a redundant pump (in case one fails), parallel radiators (in case one clogs or fans quit working and to reduce restriction).
I was planning on using 1/4" or 3/8" tygon tubing with compression fittings. I plan on placing a silver kill coil in each radiator, and perhaps one in the reservoir. Distilled water with no dyes.
Does this sound like a good loop or are there better ways to run it?
My build thread
