Well I have been hemming and hawing over a new build and I think it's time to just bite the bullet and go for it. Of course it's all going into a Norco 4224. The OS will be housed on a RAID 1 or 10 array. I have an ARC 1210 to handle all that. So I need recommendations on:
1. A motherboard. I would like IPKVM and ECC as well as an on board LSI controller to eventually run an HP SAS expander. Actually I might just scrap the ARC if I can make a RAID 10 array on the controller to boot from.
2. RAM? Registered, ECC. That's about it. I won't be needing too much at first. Virtualization will happen in the future though so I would like the ability to have at least 8 GB in the future.
3. CPU. Not sure here. This is tied in greatly to motherboard choice.
4. Anything else you can think of.
Also I probably will never have 20-22 drives for storage. By the time I get to those levels huge drives will be cheaper and I'll be moving in that direction. Should maybe I get a 4220 instead of the 4224, use the ARC for the OS, the 8 LSI ports on the board and then get a AOC-SASLP-MV8 for the remaining 8 ports?
I know these "what hardware should I get" threads are always fun, so let the games begin.
