Need some advice for system OS
shaggy77
hey,
My question can span over a couple of different forums. I was thinking either the Storage section and this section would be the best sections.
Here is the situation. I recently upgraded my main PC. The leftovers are becoming my new folding box. I will post what I am using for in a moment. However, the time has come to think about how I want to set up that box. With advancements on the Open Source front got me thinking about how I would like to handle this. Here is what got for the initial build.
MB: Abit NF-7 Version 2.0
CPU: AMD Athlon XP 2500 Barton
RAM: Kingston HyperX PC3200 CL 2.5 1 Gig kit
HDD: Well here's where it gets fun. I have (2) 80 GB Seagates. (1) 120 GB Maxtor. Which I suspect to be flaky. [Side note: My old folding box ran on 20 GB Maxtor from 1997-8 never had a problem. However I own three different 60GB models and 2 of them have died. The 120 GB has the same issues as the 60s did from the day.So yes I am hesitant in placing any data on that drive.] Right now I loaded a copy of Win 2K pro edition on one of the 80 Seagates. The other 80 Gig still have a information on it that can be useful to me at a later point so I cannot erase it.
Location of the machine: Downstairs in my workshop area. Dry air. Fairly clean environment.
Primary use of the machine: Hopefully folding for the [H]orde
Secondary uses: access to the internet. music device of some sort. Thinking about making it a file server as a safe guard due to some recently lost files like 20 gigs of MP3s :( Human error not hardware. Got stupid and don't want to think about it.
I am thinking about doing this. I would like to make this box did a bit of everything. When it is not used, fold fold fold to its CPU's content. However provide a basic service to my wife and I for file storage. My old main rig handled this function for file storage. However, my wife does not like my computer running when I am not around it cause it just runs up the electric bill. The other reason is she is working in another part of the house and them when she needs a file and my PC is not on, she has to start it up for a one file. Then she has to shut the computer off again. She has no problem with the folding rig since the electric is doing something positive plus there is no need to run my PC for files. We are not some Fortune 500 computer that needs to have several hundred computers running all the time.
So I was thinking this. Take my old 20GB Maxtor and use that for the OS. I was thinking about buying a 500 GB Seagate and using that for music, movies, and other media types. [Sorry, a HTPC is not in the cards right now. I don't have the room or the money to build another computer right now.] Or I can use the 80 GB Seagate for right now and then procure another larger HDD for more storage.
Which comes to the point what should I do for an OS? The Open Source front has come a long way into making the transition easier. I have played with Ubuntu and it felt pretty natural working in it. However, I was thinking about keep using win 2000 for this application.
So what does the [H] community think?
thanks for the advice and helpful solutions that you may come up with. If you have a question in which I did not provide enough info, ask. I will try to give you an answer.
shaggy
I'm running SUSE 10.2 as my main OS. I serve some files off a couple of the drives in this machine and have no problem with it. It does take a bit of looking in Samba settings to get folders or drives shared for anonymous access from other systems. I felt rather stupid for how long I looked for it and where it was. It was there and I should have found it sooner. The actual sharing itself is easy and I never have any problems with other machines accessing the files.
Since it's a dual core machine, I have the SMP client running and have no trouble with it. I don't know of any real problems with folding under Linux. My first Linux box was using a folding only distro and that thing ran nonstop for months at a time without a single folding problem. Only reason it would go down every couple of months was because the power would and there was no way to get it to restart as soon as the power came back on.
I'm also thinking about putting either SUSE 10.2 or FC6 or FC7 on my PIII system as it's also basically a folding fileserver. It's no powerhouse but it runs XP well enough with 512 meg of RAM so I don't see Linux being a problem. Might even make it feel a bit snappier depending on how I have it setup.
If you have some time and like to mess around, I'd see about putting Linux on it and using that as your fileserver although Win2k should work just fine. I was thinking about putting that on my PIII for a while but if I change OSes I'm going to go with Linux on it.
Personally, I'm not a fan of Ubuntu. I tried it and didn't like it as much as SUSE 10.2 or FC6. I'm not saying there is anything wrong with it; I just prefer different distros. I like messing with things so I would suggest something different from Ubuntu just to get a taste of a different distro.
ubuntu, windows 2000, or windows xp pro.
it's obviously you're call ;)
