Need some advice for a new build...
Heya guys, so I'll order a new PC from NCIX (I live in Canada) really soon, because I'm moving and starting university. Here's a list of what I've already chosen: clicky
My budget is a little bit over a grand. Basically, I need a lot of space for all my music, and I want a decent speed. I will use this computer mainly for listening to music/working/recording my music. Thus, I want a decent processor, soundcard and speakers. I also have some Sennheiser headphones that I'll use. I don't really care for gaming that much, so the GPU is low-end. Should I get one 1 TB HD, or two 500 GB HDs in raid0? Also, is it possible to ask NCIX to make the raid0 themselves? I don't see any option for that. What do you guys think about this build? Should I change stuff? Thanks! :D
forget about that Pentium dual core, get a Core 2 Duo
and also the 9600GSO is not the best choice for that price
Don't bother with 500GB RAID 0 since that's a horrible price for two 500GB Black drives. Just go for a single WD 1TB Black drive for $60 CAD less and you'll be set.
CPU wise, the E5200 is a poor choice for the money since the AMD Athlon II X2 245 outperforms it while being $5 CAD cheaper. So definitely switch to AMD:
http://ncix.com/products/index.php?sku=41542&vpn=ADX245OCGQBOX&manufacture=AMD
Additional questions:
- Are you planning on using a dual-monitor setup or what?
- Will you be overclocking?
- What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
For a cheaper cost, if you're going to have NCIX put the pc together this AMD Quad build is better. You don't need a graphics card for your needs. The onboard graphics uses the geforce 8 series GPU which is similar to a Geforce 8400GS.
Thanks for your input. After reading all the advice in this thread, I will switch to a 1 TB WD drive. To answer your questions: I don't plan on using a dual-monitor setup, and I won't overclock. I also don't need any special features on the mobo.
HardwareGuru's build looks nice. But should I modify that build and choose everything I had previously except the mobo/processor and choose a single 1TB drive?
You can do a 1TB drive instead. But, scary though if that 1 drive craps out, your left with no drives at all. If you had 2 drives, not too bad if one of them craps out.
Can they install the raid themselves? Also, what about the sound card, etc.? Should I choose the stuff I first chose? Thanks!
RAID? Raid 0 striping? Raid 1 Mirror? also, no need for a sound card when most mobo onboard video is good already. By the way, you don't need the 780a SLI chipset mobo I had in there. You can save some money and go with the nForce 750a chipset mobo and save $43. This chipset has onboard GPU Geforce 8300 graphics. Total comes out to $1,038.78
Since you're doing music recording, onboard sound would more than likely not be sufficient for you needs. As such, I recommend sitcking to your build sans CPU, mobo, HSF, and GPU but with a single 1TB Black HDD.
- Get the X2 710 or X3 720 CPU.
- Mobo wise, I recommend this mobo since it has onboard video (DVI, HDMI and VGA) therefore no need for a video card and therefore no extra source of noise when doing music recording:
http://ncix.com/products/index.php?sku=36026&vpn=GA-MA78GM-US2H&manufacture=Gigabyte
Sweet. But why is a sound card unnecessary? Can't I have a sound card and onboard video? Wouldn't it be better if I had one for great quality sound/recordings? Thank you.
Look at the post above yours. I recommended sticking with your planned setup which had the sound card in it...
Yes thank you, I just read it :D. Sounds very sweet. Thanks a lot! I will compile what ideas you guys have given me and post the finalish build a bit later. Need some sleep now.
My bad man. I forgot your into music so.. yeah you are right a sound card in your situation would be ideal. By the way, you won't consider building this build on your own? Also, I see you have not included an O/S, you have a licensed O/S already? I guess you don't need a mouse also?
Also, I think you really need better speakers than that $60 Edifier 2.1 speaker system. Since music is your primary thing, a good set of speakers is critical. Hehe, I keep mentioning about M-Audio speakers and I will again. Consider the M-Audio AV30 2.0 speakers for music listening.
Exactly, I already got those. I will use Windows XP until Windows 7 comes out. Also, I'm not sure I want to build this on my own, given my poor technical skills :D Don't want to deal with all the trouble of something going wrong...
Here's what I got so far. Also removed the cooling. Do I really need it?
Also, thanks for the speaker suggestion Guru, I might buy those instead, the reviews look great.
Here's the difference between the M-Audio AV 30 & AV40 speakers
AV40 has these advantages over the AV30:
* Bigger LF Driver by 1"
* Bigger HF Driver by 1/4"
* 5Hz lower in the frequency range (same top end though)
* Lower crossover frequency (2.7kHz rather than 3.3kHz
* Extra 1/4" line inputs (useful for connecting keyboards and electronic drum kits)
* 20 watts per channel instead of 15 watts
* Bigger enclosure
Alright, sweet! Thanks, Guru! And finally, does the rest of the PC look good? As I said, I removed the fan. Do I need one or is the stock cooling okay? Thanks!
FDD!?!? no old spare one you can just use when needed?
Switch the green 1TB out for a black 1TB. WD1001FALS.
Choose a better case... something with 2x 120mm fans (at least one intake and one exhaust). If you stick with that current case, I think you'll need more fans, as I only see one included, and its only 80mm. Definitely choose another case. Wait, there are multiple pics of the case, one shows an 80mm (8cm) rear fan, and another showing a 120mm fan, yet the specs say one 8cm fan is included. Clarify with NCIX.com which is correct, and if its only 1x 80mm fan, you'll need a better case if you can't fit a 120mm fan in the rear. If no front fan is included, add one.
Thanks. So I changed the HD for the SATA2 you proposed and chose a computer case which seems to suit my needs. You can view it here. How does that sound?
Great case choice. ;) One of my favorites. It should come with two 120mm fans, and can take up to 5 more (7 total).
Heh, I had no idea that you could have chosen another mobo or other parts that wasn't listed in the configuration. I guess just needed to click on the advanced link to do that. :rolleyes:
