- Dec 3, 2006
Gaming - Starcraft 2 (highest res&detail possible hopefully) Eve Online, COD etc..
Budget is around $900 with tax and shipping to CA
3) Where do you live?
zip: 94545, CA
I need:
small form factor case (something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16856101092)
CPU & heatsink
RAM
Motherboard? (I never built a shuttle before but i see some shuttles that include this with the case)
PSU (same case as above)
Graphics card (thinking of a 460)
wifi card? (unless built into mobo)
Monitor
LG DL DVD drive
120gb OCZ vertex I SSD
2tb WD EARS HD
Logitech MX3200 mice keyboard combo so i'm good with this
6) Will you be overclocking?
maybe. meaning if its only a ~5 fps change, probably not.
No monitor but want a 22-24 LCD LED w/ HDMI (I prefer a bigger monitor since i'll most likely use this for my xbox as well.)
around March
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
No need for SLI but USB 3 would be nice. SATA 6 probably not needed. built in wifi would be nice.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes I has Windoes 7 Ultimate x64
Thanks for any and all advice! I don't have much room in my room so a shuttle would really be nice. I'm ok with full size machines but shuttles for some reason just confuse me, mainly the size constraints. Would like a system that isn't too loud.
zip: 94545, CA
I need:
CPU & heatsink
RAM
Monitor
LG DL DVD drive
2tb WD EARS HD
around March
