Moderate gaming (World of Tanks), Adobe CS5 suite (Photoshop, Premiere, InDesign, Illustrator, Flash, Dreamweaver), Engineering software (Matlab, Xilinx, LabView, etc.)
Hopefully less then $600 for the CPU, CPU cooling and motherboard. All the other part upgrades are of very low priority. Tax and S/H not included.
Los Angeles, CA
4) What exact parts do you need for that budget?
Intel CPU (leaning towards i7-2600k or a i5-2500k)
A solid motherboard for overclocking (mATX or ATX is fine)
CPU Cooler to achieve satisfactory OCing results without being horribly loud. (Most likely a self-contained water loop like those Corsair H100's)
Nvidia 8800GTS 512mb G92
Corsair HX620
(2x) Mushkin Enhanced Silverline 8GB kit (PC3 10666)
Some ATX Case that has a single 120mm rear fan.
Rebranded Intel X-25M 160gb SSD
6) Will you be overclocking?
Most likely, I want to try to achieve a 4.5ghz+ with less fuss as possible (from what I have heard from many people).
(2x 22") 1680x1050, would like to expand to more monitors in the future.
Hopefully within a month.
9) What features do you need in a motherboard?
USB 3.0, eSATA would be good bonuses but can shove in an add-in card if this limits motherboard choices. CFX/SLI is necessary for driving multiple monitors.
Onboard video or RAID is not necessary.
Yes. Windows 7 Professional, 64-bit
I am not up to snuff about which best bang-for-buck parts to build a new PC from, but I am aiming towards features that can somewhat future-proof the computer as long as possible, such as IB compatibility for certain NB chipsets.
Also barely leaning towards an mATX build so I can lug it around easier.
Los Angeles, CA
Corsair HX620
