runLoganrun
- Jul 4, 2005
it seems like i have to buy something like Areca ARC-1220 to have good performance, and better reliability than something like one of the 8 port Rocket Raids, this is unfortunate as they are considerably more expensive. I want to build something reliable though that will last a long time hopefully with very few problems. Any other suggestions welcomed.
the purpose of this is to build a storage device/ server to sit on my small network. thinking of something like asus p5ql/775/p43, intel celeron wolfdale 2.5G, and 2G of ram.
my first question is that in the specs for the controller i mentioned, along with many others, they specify server 2003, but not 2008, will it work with this OS? and, this one mentions that it works with vista, does that mean that most of them don't?
I haven't decided what would be best OS to put on it, not sure if i need to have server OS, i figured i could just setup vista or win7(if supported) and setup shares on that, but want to know if server os would be better. it's just a couple computers on it now, it might expand to 1 or 2 more, idk, but essentially just needs to be a large storage capacity nas type deal.
also, if using a hardware type controller like this one, what is it dependant on exactly, like for example if something happens to the card, am i screwed, or if i replace with identical card will the array still be intact? The same for mobo, and could it be switched to a different motherboard by just moving the array with the card? the os would be on individual drive.
thanks for any help,
rlr
rlr
