need quick comparison help for a friend
Atherton213
my friend is looking for a graphics card to finish off his system... he needs a pci-e card
what card?
x850 xt platinum
or
6800 GT
which is better? thanks
(sorry if this is posted before i didnt search... i just need a quick answer)
X850 XT will blow the 6800 GT away but it costs $459.00 dollars more than a 6800 GT.
Go for the X850XT PE... it will own the 6800GT, as said above. At that price, it's not a bad buy :).
it's a great buy. But your chances of actually getting it within the next month are slim.
The 6800 GT can easily be overclocked to 6800 Ultra speeds. Which isn't too far off from X850XT-PE speeds. Sure the difference is noticable. But at least you can actually get the 6800's.
