Need quick advice - 939 or AM2
Varmint
I'm building a PC for a buddy who's very cost sensitive.
Basically trying to decide between identical 939 and AM2 systems:
3200+ retail
Biostar 6100 motherboard
512 MB ram etc
The 939 system is $380, the AM2 system is $420.
He'd appreciate the $40 savings, but I'm wondering if 2-3 years from now, 939 parts will be more expensive (DDR vs DDR2, and CPUs)?
si0dine said:
939 is already obsolete, and AM2 will be obsolete very soon as well.
Therefore might as well save money and buy the cheaper 939 parts? Chances are he won't upgrade the system anyway unless something dies.
i know 4x4 is coming out, but how could AM2 be obsolete if it's only been out for a few months? (like6) :confused: :confused: :confused:
Where are you buying your parts?
I'm building a system with a Pentium D 915, Foxconn 945P motherboard and 1GB PC2-5300 RAM for $315.
If he's not going to be upgrading go with the chepaer option. There's not really much performance gain going with AM2 over 939.
It's not "obsolete" yet. But AM2+ and AM3 are coming out later in 2007 and 2008. However processors for both of those will be backwards compatibile with AM2, just without whatever enhancements their native sockets would have offered.
I'd get the AM2 setup only because it's theoretically better suited to upgrade in the future.
Yup, I went AM2 on my latest for DDR2. Besides, I know you say you won't upgrade for a while, but if/when you want to it's gonna be there.
Newegg w/ the free shipping. :)
Coolermaster Centurion 534 = $50.00
1x512 Corsair MB DDR PC3200 = $53.00
Athlon 64 3200+ retail = $60.00
Seagate 250 GB 16 MB cache = $80.00
Biostar TForce 6100 = $60.00
Thermaltake 430W = $38.00
LG DVD-RW = $30.00
Sony floppy = $8.00
Total = $379
I thought about going Intel, but I'm more familiar with AMD parts.
LG DVD-RW = $30.00
Sony floppy = $8.00
Total = $379
Oh, okay. You're building an ENTIRE computer with that, not bad. The only things I'd' change is the PSU.. Thermaltake is one of those brands that is recommended to avoid unless you're getting one of the Toughpower models.
Also you can get a stick of Wintec AMPO 512MB RAM for about $5 cheaper. I had four stick of that and never had a problem, Plus they ran well below their rated timings. I got mine from 3-4-4-8 down to 2-3-2-5 at stock speed.
Either way, definately get a different PSU.
Look around buy.com for CPU's. With Google checkout you can usually get a good deal...better than newegg.
Too late, ordered it - but I have a similar Thermaltake in my PC, and it's fine, plus it has 5 stars on Newegg after 1000 votes.
Yeah, might get the Wintec, thanks! Haven't ordered mem/CPU or motherboard yet.
Can you or anyone suggest an equivalent Intel combo of CPU/motherboard w/ onboard video, in the $120-150 range? Is there such a combo that's upgradeable to C2D later?
Did a quick check and Newegg was cheaper even after GCO. But I'll keep an eye on it, thanks.
Dont know equivalnet but I found this after a quick search
ECS P4M800Pro-M -- $46.99
http://www.newegg.com/Product/Product.asp?item=N82E16813135027
Pentium 4 531 -- $78.99
http://www.newegg.com/Product/Product.asp?item=N82E16819116230
Total 125.98
I imagine the A64 and Biostar combo you already had picked out would be quite a bit faster though.
If you're going to go Intel, at least get an 805 or so if you're not going C2D right off the bat. They are around $95 or so maybe. Can get them used in FS/FT pretty cheap I'd imagine.
Thanks guys, doesn't seem worth getting Intel unless you spend for C2D.
Dual core at $90 or so is a good deal. OC's decently too even at stock voltage. In a budget machine, a 805 will do about 3.2-3.4 with stock voltage. That'll compete with AMD CPU's at the price point.
Oh, didn't realize that's a dual core. My friend's not going to overclock, I don't think he even knows what a BIOS is. :)
Lol...at 2.66Ghz (stock), the 805 really isn't all that fast at all, but if you clock it over 3.0Ghz, it's not a bad machine for the price. I'd pay an extra $10 for that over the 531 personally.
I'm leaning toward ordering my friend the 939 3700+ (2.2 GHz w/ 1 MB cache).
939 3700+ 1 MB = $72 ($10 off w/ Biostar combo deal)
AM2 3500+ 512k = $85
I have a hard time spending more for AM2 just to get less performance. Yes, I know that's probably a hangup. :)
What kind of memory are you putting in it? DDR2 memory is usually a little cheaper than DDR1.
Just a 512 MB stick - I found DDR was $5 or so cheaper when you're buying basic $50 stuff anyway.
High end DDR is probably pricey.
I guess at that price point, s939 makes sense, but if you're moving to dual cores, the X2 3800+ AM2 can be had for $130 or so and the cheapest in s939 is $150-160.
I'd definitely take the 3700+ s939 over the 3500+ AM2 unless I had serious plans of upgrading it in the future. If you're planning upgrading, I'd definitely get AM2 anyway only because DDR prices are going to rise as the supply dries out, and it'll be easier to get AM2 CPU's in the future.
My friend's PC is like 10 years old - it has a 4 GB hard drive. I just have a feeling whatever I build him it'll stay that way for another 10 years. :D
I also had trouble finding a good AM2 motherboard too - every single one seems to have issues. Lots of stable 939 motherboards by comparison.
Built the PC today for my friend - it runs great - in fact it seems slightly snappier in Windows than my PC, maybe the 1 MB cache of the 3700+? I wouldn't guess that does anything. I'm itching to OC the 3700+ (Opteron CCBWE core), but I won't.
Coolermaster Centurion 534 = $50.00 (-$10 rebate)
2x512 Corsair Value DDR PC3200 = $98.00
Athlon 64 3700+ retail = $82.00
Biostar TForce 6100 = $60.00 (-$10 rebate)
Thermaltake 430W = $38.00 (-$10 rebate)
LG DVD-RW = $30.00
Sony floppy = $8.00
Total = $395 after rebates
The Biostar motherboard seems nice, though I think the bios in my Epox is easier for the novice overclocker. The Thermaltake PSU was making a throbbing noise for a bit - too cheap I guess.
