Need processor advice, been out of touch for a while
Sly
Been having a real hard time finding comparisons between these.
In our local PC supplier, the prices of these are about 5 dollars away from each other.
Need to know which is faster of these two:
Intel Dual Core E2200 2.20Ghz 1MB
AMD Athlon 64 X2 5200+ 2.6Ghz
And these:
Intel Core2 Duo E7200 2.53Ghz 3MB
AMD Athlon 64 X2 6000+ 3.0Ghz 2MB
AMD Phenom X3 8450 2.1Ghz Triple Core
I'll keep googling but i really can't find reviews comparing them so i'm hoping some of you guys can help shed some light on this.
If you plan on overclocking, the e7200 will be the best of the bunch hands down. There are folks hitting 3.6ghz+ on this cpu. At this point, your system will be GPU bound for the most part.
Between the E2200 and X2 5200+ cpu, the X2 5200+ is a little faster but the margin is small. If you will O/C then then the E2200 will pull away easily. The E7200 is the fastest among the 3 you listed whether you O/C or not. No doubt, get the E7200 cpu over the X2 6000+ or Phenom X3 8450.
Thanks. Actually i was leaning towards the e7200 mainly because it's only 65w and apparently runs cooler. I live in the tropics and the cpu fan's always at 100%, when i put it on the desk, it feels like i have a mini vibrator under the keyboard, hopefully the fan'll quiet down this time. Nice to know it's good for speed as well.
My next problem now is the motherboard. Unfortunately, the selection here is pretty limited so i'll just go with whatever they have in stock when i head over to the store. Thanks guys.
BTW, i don't overclock. I normally sell my old rig to help pay for the next one, so i need the CPU to last. It's also a good selling point when i say that the CPU has never been stressed.
Final Specs
Gigabyte GA-945GCM-S2L AVGlan/DDR2/PCI-E (Or whatever they have if this went out of stock too)
2x 2GB DDR2 800 Kingston
Inno3D 9800GTX
Looks like the mobo got some really strong negative comments.
Can you guys help me narrow down my choices by recommending a good chipset?
Try to find a motherboard based on the P45 or P35 chipset.
Thanks for the advice, the delivery got delayed so i won't be able to pick it up for a day or two but i've downloaded the manuals to get the detailed specs. The mobo i got is Emaxx P35-Pro Intel P35, but one thing i didn't notice until i checked the manual was that it had a 4 pin molex on the board! I've checked other P35's and i don't think i've seen a molex in any of them, so what is this one for?
It's on the upper left. I'm not even sure if the PSU cable will reach that far.
Its most likely to provide extra power to the PCI-E slots, if needed. If you're only running a single vidcard, and one low power or no other PCI-E cards, then you don't need to plug in the molex connector.
OC'ing is easy and doesnt lower the life of the CPU if heat is kept in check. However, since you live in the tropics, stock speed should be fine for you. :p However, a slight bump to 3Ghz should be easy and still have good temps with no voltage changes. Keep in mind, all CPUs of a particular core are made on the same silicon... Intel makes 3 models, and bins out the rest accordingly from the same silicon.
