Need Power Supply, suggestions please
Kliter
My system will be a Q6600 with a Geforce 8800GTX. I might go SLi later on, but it would be with like an 8600 or something (with SLI version 2). I won't be doing any overclocking either
So I'm thinking I'll probably need atleast 600w. Quality and stability is obviously a top priority.
Thanks
Alright, well to help you all, I've narrowed it down:
SeaSonic S12 Energy Plus SS-650HT ATX12V / EPS12V 650W Power Supply 100 - 240 V UL, CE, CB, TUV, FCC - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817151028
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817139002
Thermaltake W0106RU Complies with ATX 12V 2.2 & EPS 12V version 700W Power Supply 100 - 240 V CE, CB, TUV, FCC, UL, CUL, and BSMI certified - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817153039
Thanks
Take either Corsair HX 520W or 620W, or Seasonic S12 500W or S12 600W (or SS-550 / SS-650). You could also consider Silverstone Element 500W Plus - it's great PSU, plus it's very powerful (it has over 430W on combined 12V rails).
Seasonic or Corsair (which is made by seasonic).
Thermaltake PSUs are just ok....Seasonic and Corsair are awesome (from what I have seen/read)
Most definitely a Corsair HX620W. They have proved their reliability and power combined with silence in numerous tech reviews.
