Yes. Had to do the same for a PERC 5/i & H700.
What I don't remember is if the brackets came with screws.
I don't believe they did, but any old similar full-height PCI card with a bracket
will have screws you can use.
Your solution...
http://hardforum.com/showthread.php?t=1459008
Even with screws scavenged from other cards, they were hard to thread in. So don't break your card... I wound up using and destroying one screw as a tap (while off the card), before I was able to get any screws that I had on hand to fit.
