Need opinons on system build.
CDdude55
Here it is:
CPU: Intel Core 2 Duo (E4400) 2.0ghz
Mobo: Evga 680i SLI SE
Video card: Evga 8600 GTS 256MB
RAM: 2GB OCZ Gold DDR2 800
PSU OCZ Xstream 600w
Im not overclocking. So what do your think?
looks good, but the 8600 gts i heard isn't worth getting. you might as well get a cheaper video card and it can still perform equal or better than that card.
- What's your budget?
- What size monitor do you have?
- What are you planning to do with this new PC?
- If gaming, what games are you planning to play?
Like turino has said, ditch the 8600GTS. Go with the x1950Pro instead. It's cheaper and offers the same amount of performance, well in DX9 games anyway.
Here it is:
Your parts seem mismatched.
You have a 680i SLI board with only a 8600GTS, but also have a 600W PSU. If you're using the 86 as a holdover card, I'd strongly suggest a cheaper card instead, like the X1950GT for $110AR. If you're not planning on SLI in the future, you could drop the board down to a GA-P35-DS3R or IP35 Pro.
Its always good to have more than enough power, but 600W is overkill unless you plan on getting a GTX or Ultra version of the G92, imo. If you wanted to upgrade to SLI, you'd need something stronger. Otherwise, you'll be fine with a 500W XClio goodpower or 5150GH Enhance 500W PSU instead.
SLI is only needed for high resolution 3D rendering -- think 24" LCD (1920x1080 or higher). Otherwise, don't pay for such an expensive board if you don't have or plan on getting such a large monitor, as you won't notice the benefits of SLI.
Also, OC'ing a Core2Duo is easy, you'd be wasting such good potential by not tapping into it. Even a modest OC would keep the voltages near stock, preserving the longevity of the chip. These chips have so much headroom, they're stable at 1Ghz OC'd speeds!
