Need opinions on system build.
CDdude55
Here is the system i am planning to build. I don't want to overclock but i do plan to do SLI in the future.
Intel Core 2 Duo (E6300)
Asus P5N32-E SLI Plus
Corsair XMS2 Ram
Evga 8800 GTS 320mb
Corsair 620wHX PSU
WD Caviar (160gb)
So what do ya think?
even though you dont plan on over clocking you would probably get more out of your SLI in the future if you had a little bit more clock speed on that cpu.....put a decent air cooler on it and you will probably get alot more bang for your buck
Thanks for the advice. i picked that CPU because it was very cheap and didn't want to spend so much on the CPU.
Buy that CPU after the Intel price cuts on April 22nd. It will be $163 then.
Or for the same price as E6300 before price cuts, you can get E6320 which has double the L2 cache, after the price cuts.
Why do you want to do SLI in the future? Do you plan on getting a large LCD screen?
SLI is basically a technology that lets you use two of the same graphic cards at once during gaming. You'll also get a slight performance boost. To many people, this means that they can buy one relatively cheap graphics card now and buy that another of that same card later. However, the problem with that is that there will always be a single graphics card that's much faster than any two graphics cards in SLI and it will most likely be cheaper too.
I know what SLI is. But i didn't know the part about one of the cards being faster then the other. interresting.
SLI is only needed if gaming at extremely high resolutions (24" or larger LCD, maybe even 22" for some people). Otherwise, a single card solution would be best.
Ok thanks! i might get a XFX 8800 GTS instead of Evga.
i wouldnt recommend sli, especially with your build
1) unless u game at high resolutions your performance will be limited by your cpu, especially since u wont oc
2) 320mb will seriously bottleneck your sli performance. u need the 640mb version to even consider sli
