Dangman
Ninja Editor SuperMod
- Dec 15, 2005
A guy at work was talking about i5.I have no clue about this can you fill me in?
Core i5 is the mainstream version of Intel's Core i7 CPUs. The Core i5 uses a different socket, LGA1156 (Core i7 uses LGA1366), so you cannot use them interchangeably with current X58 motherboards. The Core i5 is suppose to be the cheap mainstream while the Core i7 is suppose to be the high-end high performance enthusiast class CPU.
The Core i5 is suppose to be released in Q4 2009 IIRC along with the P55 chipset. Speculation so far is that its performance will be just a bit faster then current C2D/C2Q setups judging from the performance of Core i7 CPUs so far. In fact some rumors pegs the some of the Core i5 CPUs being almost as fast as a stock clocked i7 920 when OC'd while being slightly cheaper.
